Shed Shelves
Dick H.
>What sheet goods material is the best for shelves in a garden shed? The shed will not leak in the rain but there will be some expected moisture from mother nature. Nothing fancy just able to hold the usual garden "stuff".
Shed Shelves
Dick H.
Re: Shed Shelves
Virgil Johnson
>Depending on the span I would use 1/2 -3/4 CDX plywood. CDX means one side C grade other side D grade with X exterior glue.
Best shelves ever
Mark Goodall - ATL- tooljunkie
>I no longer use plywood or anything else for shelves.
I use SYP (Southern Yellow Pine) in either 2x8, 2x10 or 2x12 sizes.
Fantastically strong and looks just great. I've got it in the sunroom, garage workshop and shed(s). A little more expensive than 3/4" plywood, but much nicer in every way. Did I mention I love the way it looks? It darkens slightly with age and looks so good.
Happy Woodworking!
Re: Shed Shelves
Clint Searl
>This situation does not deserve overkill; 1x #2 pine from the Borg is all that's called for. If you want to go First Class, Teak or Cuban Mahogany would also work.
Clint
Re: Best shelves ever
Virgil Johnson
>"It darkens slightly with age and looks so good."
This is most important when designing for for a shed.
It is for me
>I'm assuming you're saying that with a wink ;)
I've just finished building another shed... and shed extension, if you will..... and things like that matter to me. My sheds are better built than my house... cause I built them :)
And I've pulled out all the plywood and 3/4" pine shelves in my house, garage, sheds and have nice looking 2" shelves.
This is important if you value you workshop/garage as much as the inside of our house... and if you're hear at Wood Central I know you do.
It's also important for your shed, because if you don't have a dog house, it's where you spend the night sometimes ;)
For some reason, 2x SYP wood is relatively inexpensive... around here at least..... no reason to use 1x pine, whitewood or plywood, escpecially when it's less expensive in some cases.
Happy Woodworking!
Re: Shed Shelves
Lewis Dodd
>Wellllll.....here I go and open my yap again. Shelving in my opinion, I say again, IMO, is much like a trailer. Cheap don't cut it!! Sooner or later you or someone else is gonna overload it!
Lewis
Re: It is for me
Virgil Johnson
>yeah. forgot the :-)
& sooner or later the sky will fall
Clint Searl
and when it does.......
>..... we'll be able to sit underneath our shelves and stay safe!
I know I will be ;)
Happy Woodworking!
