A55 Smoothing Plane
source for 12" H&L sanding disks
Carol Reed - home in Strawberry
>Years ago I cobbled together a disk sander that uses the 12" hook and loop sanding disks that Shopsmith used/uses. They no longer stock them.
I have been out of woodworking for so long I no longer know the usual places to look. Any help? Especially if you also use them?
Re: source for 12" H&L sanding disks
Klingspor
Bill Tindall, E.TN
>the industrial division, not the store, will custom cut any product they have in bulk rolls and this would include hook and loop.
Re: source for 12" H&L sanding disks *LINK*
Bob Entwisle in NJ
>Klingspor has them.
There is a woodcentral link to Klingspor, but I couldn't seem to find the 12" H&L disks there.
Here is s link to the 12" H&L disks, maybe give them a call and tell them WoodCentral sent you, so Ellis/WC gets it's cut.
http://www.klingspor.com/products/klgprPSA.htm
Rick L
Re: Sandpaper...the real story *LINK*
Rick L
>Klingspor is ok but Industrial Abrasives is a much better source. As a purchasing agent I buy from many sources and large quantities. Ind Abr always comes out on top and even though they are mostly known as an industrial source they will deal just as easily with the hobby folks.
Lowest minumum on custom belts.
Quality sandpaper priced right
Lewis Dodd
>Hey, thanks for the info and the link! The wood turning club has been using Klingspor and even with our "discount" it appears your link is less expensive and with better options.
Lewis
>Thanks, Rick.
Price is good, too!
sll sand paper is not created equal
Bill Tindall, E.TN
>There are many components to a sheet of sand paper and more so to hook and loop or belts- abrasive composition, structure, size range and distribution , bonding adhesive, substrate, to name a few. Each component is an opportunity to cut cost and maybe cut quality. Being overly enthusiastic about just the price may not get one the best value. And, an industrial sounding name doesn't ensure quality either, especially when it is associated with a low priced product (think Harbor Freight product names).
Until I use it I don't know how to judge the quality of most woodworking supplies. I have found that country of origin to be a good guide when in doubt. Some countries are noted for making the best quality products while others are not. Some applications merit quality materials while others don't.
If anyone is interested in the lowest price 100 sheet rolls of 5" PSA disks, 220 to 80 grit, contact me as I would like to be rid of some. They will stick to your ROS and they will remove wood if these and price are all that is important.
Question
Bill Tindall, E.TN
>If your turners find any product more cost effective than the Klingspor cloth flex back abrasive (the green stuff) I would be interested in learning about it.
I presume the club is ordering from Klingspor's industrial division and not the store.
Re: Question
Lewis Dodd
>Well Bill, I am speaking a bit out of turn as I have not ordered in a long time. We have a special account number and I always order the box quanity for turning. I get a mixture of the gold and the green. Problem is, it is floor scraps and I have gotten too much coarse before and not enough fine. Also, some pieces that were virtually unusable for my purposes.
Lewis
C. John Hebert
>......and you can't beat the service!! I've been using them for 40 yrs, and got their address from my mentor. I think I was the first to post it on the net years and years ago, and from then on satisfied users have also passed it on. A great outfit (no affiliation)
Well duh!
Bill Tindall, E.TN
>You are ordering mill ends and rejects through the retail store from their industrial division manufacturing operations. You get what ever they have trimmed from what ever they are running at the time. Because the green and gold products are mostly used in manufacturing in the coarser grits that's what is commonly available in the mill end box. You are buying it at a small fraction of this product's normal price, because it is mill ends and rejects. This stuff lasts many times longer than a paper backed abrasive for lathe and other machine sanding so I find it to be cost effective even at the normal factory price.
When I visit the store I "dumpster dive" in the box this stuff comes from and usually find some grits in the range of 120-220 which I use mostly on my spindle turning. Occasionally I have found large expanses of desirable material in the mill end box.
You can order it by the square foot (or meter) in in rolls of any width from the industrial products division which is not connected to the retail store.
Rick L
Re: Nattering nabob of negativity...
Rick L
>Try Industrail Abrasives. Local PA company and sandaper is all they do. Have been using it in commercial wood and metal shops for 25 years.
