We value your privacy.
>I am looking for the best blade for splinter free cross grain cuts. The material is 3/4" baltic with satin wood veneer. I have never used a melamine blade but have heard that is the bees knees for this.
>Melamine is the worst to cut. A Hi-AT blade from Forest is the pioneer in this category. Others have since jumped on the bandwagon. You can get splinter free cuts in finished sheet goods with a good plywood blade and a fresh zero clearance insert. Blue tape will help if your blade isn't the best or a bit dull.
>A high quality HiATB grind blade with lots of teeth and low or negative hook is best at shearing the fibers and reducing splintering to about nil. Blade height is critical. If you choose the Freud version (LU80R010) you should start with about 1/2 of a carbide tip above the material. If you experience splintering on the exit side lower the blade slightly and if you get splintering on the top raise it a little.
