powder coating MDF?
powder coating MDF?
powder coating MDF?
Dale Sherman, Manlius, NY
>Does anyone have a good resource for powder coating MDF in a small shop? I'm looking for a durable, smooth, and preferably water resistant surface on MDF. I need to do this in small (20-50) batches. The quality finish and speed of this method is appealing.
I'm finding large shops that want to do large lot runs. I see Harbor Freight and other sources have powder coating tools and ovens for the small shop, but I believe they're geared towards metal parts.
Any suggestions?
Dale
Re: powder coating MDF?
Dave Anderson (PacNW)
>I don't think that powder-coating and MDF is going to work. To get a smooth durable coating use "Hammerite" paint. This paint is tough as carbon steel. I have used it on MDF for years and never had it chip off.
Advise worth what you paid for it,
Dave (PacNW)
Hammerite vs. Plasticote?
>How does Hammerite compare to Plasticote? What would you recommend as primer? I'm concerned that the machined edges need a good sealing first to get a smooth final finish.
Dale
Sealing MDF
>Glue size is the preferred method (see Homestead Finishing), but I have use thinned PVA with success. Cut regular white glue 50/50 with water, and apply several coats to the "end" grain. Allow to dry between applications, and you can tint the sealer with TransTints or Rit to match your top coat color. Sand lightly before applying your paint. Hammerite is a good coating, but it's still paint (used by Stubby Lathe). Powder coating IS for metal; suspect the MDF would not take the curing heat, but not sure. Thing is, the process requires a slight static electrical charge on the piece being coated, so doubt that will work on MDF.
m
Re: Hammerite vs. Plasticote?
>The only comparison between Hammerite and Plasticoat is they are both paint. Hammerite is the king of paints. I use gray Automotive primer to seal the edges and of MDF, sand lightly then top coat.
Dave (PacNW)
Fred Davis
Re: Sealing MDF
>All the info I've found about powder coating MDF is that it requires a high quality MDF and is usually done in larger production shops. It's a very fast cure time (minutes) with no VOCs. Need a convection oven, catalytic oven or UV lights, depending on which powder coating is used.
I'll probably try several different sealers to see which gives the best results.
Dale
Earl Kelly
>If you have the spray experience and minimum facilities try ML Campbells Euro Bild. It is a catalyzed finish, 2PK poly.
The Super Sealer will seal the MDF completely with 2 coats, so you can sand it glass smooth. Then at most 2 top coats will give you a slick finish.
I used some on some interior trim pieces for a Rolls Royce rather than polyester. The sealer after sanding, filled the grain not only on the solid walnut door pieces but also the walnut burl veneer work. After that I shot 1-2 coats of the Wet Look sheen to finish them off. These were the Euro X for exterior.
Earl
I know a company -
Philip Berman
>http://www.dvuv.com/
Company is located in Cleveland and has a powdercoating process utilizing ultraviolet light and lower temperatures to allow the coating of MDF. The process creates a fully-encased, liquid tight scratch proof coating. The one catch is that you're going to have to have them fabricate the mdf for you - the powdercoating process will only work on a narrow range of moisture levels in the mdf, otherwise the powder would just fall off. I know nothing about their pricing, but I do know that they can do small runs of an item.
Re: Sealing MDF
Philip Berman
>Take a look at www.dvuv.com. I was involved in a capital-raise for them and learned quite a bit about their product. The powder is sprayed onto moisture-controlled MDF parts and cured through ultraviolet light and low heat. When visiting them, I had wanted to run a push-stick through their system (just because :-)), but they explained that the MDF must be within a certain moisture level to get the powder to adhere. Very cool product.
Yes possible
Kevin Rabenaldt
>I saw that a company provides MDF cabinets for Garages that are powder coated in a magazine called Closets (trade publication). The process may involved a different method of application as stated in the above comment but it appears to be possible.
Kevin
