We value your privacy.
>My wife's computer has gotten extremely slow. It is on the same line with mine and mine is very fast. My question is about some of the free downloads that are supposed to clean it up and restore it to speed. I have heard that some of them actually make things worse. Ideas please.
>In the past when I was running Windows, I would usually restage it if it got too slow unless I could pinpoint something specific that was causing it. You can run the taskmanager and see what is running and what resources it is using.If the machine has been running for awhile, I would be tempted to save the data, wipe the disk and start over.
Unless someone here or that you know has tried whatever you are thinking of and can verify that it works, I would not trust it. Many of those are actually spyware themselves.
>I'm not a computer expert and don't have any idea of your wife's usage but on our old computer, simply upgrading the amount of memory had a big impact on the overall speed. The cost was about $50 and it was as easy as plugging it into the board. We actually had to upgrade the memory since the newest version of Kodak software wouldn't work with the amount of memory that came with the system. We've since upgraded to a newer and better system but upgrading the memory worked at the time.
>I had the same problem. I got Auslogics Boostspeed for $29 and was very impressed. It has tools to erase tracks, control what runs at start-up, shred memory beyond recall, and defragments at light speed, and a bunch of other goodies. You'll like it. Easy download and set-up; No spyware; No problems.
It could be as simple as getting bogged down with extraneous cookise and a need for regular maintenance, Go onto your browser and delete all cookies. This will require to log back in the first time back to each site. Also go to systems tools and do a disk cleanup and a de-fragmentation. These three things can make a huge difference, especially on a machine with somewhat limited capabilities.
>There are many things that can cause the symptoms you describe; from malware infestation to hardware problems. The malware problem is easily detected (although not always fixed) by an array of programs available for free. Spybot Search & Destroy is a good example. Danger Will Robinson!: don't go downloading random programs offering to fix all of your problems -- many of them are major problems themselves and mean to do the users harm.
The key to figuring out why the machine is slow is observation. Is some single process eating up most of the processor cycles? Disk accesses? Memory? Is the disk thrashing excessively? I've seen at least two computers which had memory problems in which half of the installed memory became inaccessible causing the computer to begin using the page file on the disk far too much. This can slow an otherwise-capable computer to a tenth of the normal speed.
>Well, I have deleted cookies, done the disc cleanup, and defragmented C-drive. she has 90% free space. I will see if it helps. Thanks to all for the suggestions.
>Another thing to listen for is any unusual disk noises. Clicking noises from the hard disk indicates that it is having to re-try read and write operations. This can slow things down a lot, but that's not the worst of it.
Excessive re-tries means that your disk is not long for this world. If you catch it soon enough, you can replicate the disk and replace it before it fails completely.
