We value your privacy.
>Does any one own or have experience with an over head router such as an Onsrud,Ekstrom Carlson, or SCMI? I am thinking about buying one for the school to use in routing the bench dog rails in our work bench class. I am now using a template and Porter-Cable 3 1/4hp plunge routers. thanks, Mike
When I was in the custom business, we used the overarm router (pin router) daily. It is such a versatile machine and nearly indispensable for pattern routing and other operations that require templates, such as fluting. It was excellent for panel raising, bullnosing, mortising, grooving, molding and a lot of other things.
One very useful advantage of an overarm router (that you don't get with a table router or an inverted pin router) is the ability to think in terms of the thickness of material between the bit and the table -- in other words, the remaining material rather than the material being removed. Couple this with tablesaw and router table operations and you can be highly accurate in situations where that remaining thickness is critical. You'll see what I mean.
Also, by using pins of different diameters, you can quickly change the relationship of cutter to template. I used to make a lot of custom pins of oddball diameters out of lignum vitae for special jobs.
I know this all sounds pretty abstract, but you'll learn as you go.
If you're interested, I actually have a large industrial pin router that is available because I doubt I'll ever need it, as I'm trying to scale down. It is an Italian machine: three-phase, 7.5 HP motor, two speeds, a tilt head, pneumatic plunge head (a very useful feature), servo-assist table raise/lower (by foot pedal), and a custom made draw collet for the pins. I've never even used it. It weigns probably about 1500 lbs, maybe more, so it won't be trivial to ship it, but anything is possible. I haven't figured a price, but I will if you're interested. Thing is, ever since CNC machines came on the market, manual pin routers have been phasing out. TMS (check our marketplace) probably lists a bunch of pin routers at giveaway prices.
To the point, you'll never regret getting an overarm router.
>We had a hefty pin router in my shop in PA. It's a great tool as long as you ensure that the head is exactly over the pin and that the pins are centered. Any variance is doubled, since it follows on all sides. Ours was paired with a small second operation lathe, on which we made accurate pins. Shaving pins just a few thousands lets you dial in very accurately fitting or nesting parts. As a result, we eventually generated a whole rack of pins, marked with their size, that varied a few thousands of an inch off standard sizes. That let us keep our parts accurate when our bits came back sharpened and therefore slightly smaller in diameter. That, to me, was the real strength of the pin router.
