Angled pegboard holes
Nandy
>I am looking for suggestions on how to drill 1/4" holes at a 20 to 25 degree angle in a 1/2� or 3/4� sheet of 4� x 8� finished plywood. The holes will be 1� apart center to center. It�s basically a thick pegboard but with angled holes. The holes will need to go as deep as possible WITHOUT going all the way through. We will be making many sheets of these. Suggestions on how and/or who can do this would be greatly appreciated.
Re: Angled pegboard holes
Re: Angled pegboard holes *LINK*
>Lay out the angle on a block of wood; drill it. make some marks to center it on your layout. Mark the drill bit OR plane the wood down to the correct thickness to stop the chuck when the hole's reached correct depth.
There are also available drill guides that can be set at an angle and have a positive stop. This might be easier; plus, you can use them in future for other things. Woodcraft's offering is linked below; "angled drill guide" on Google will give you lots of possibilities.
If you decide on Woodcraft's, remember to go to Woodcraft through the WC Marketplace (link to Marketplace at your left), so that Ellis can get some of the profit from the sale.
Remember to go in through the WC marketplace
And I'd add...
Grant in Iowa
>Bill is right on the money here. An angled hole through a block of wood is a great way to control hole angle, location, and depth.
I might add the option to create a larger jig with an entire row of holes and a means to index the jig to a layout line or maybe the previous row of holes for uniformity and ease of completing the task.
Regards,
Grant in Iowa
Curly Smith
>Here's a link to what Bill first described: Jig for Angle Drilling
You'll also want some peg board that has holes 1" O/C.
First, attach the block or drilling guide to a small piece of plywood, overlay a piece of peg board such that the drill is centered in a hole and drill two holes through the plywood (the same size as the peg board hole) from the side with the peg board.
Next, either overlay a full sheet of peg board on your plywood or make a large "T-Square" from the peg board. Use 1/4" dowels to register the drilling block to the peg board. If you make the "T-Square" then you'll need 2 more dowels to register it to the previously drilled holes.
Then just drill away. The dowels in the drilling block will keep the holes in a straight line and uniformly spaced.
Unless my arithmetic is wrong....
Howard In Toronto
>You need to drill 4,465 holes into ONE 4x8 sheet of plywood at a repeatable 20 to 25 degree angle.
Save your sanity.
Call CNC woodworking shops in your area.
They'll be finished before you finish drilling one line of holes after praying you'll manage to register everything 100% accurately.
And with precision you'd NEVER achieve by hand using jigs.
You say you need multiples of these plywood boards -
1 - if they're for a personal project, find the money, maximize your time and just move on to the next part of your project.
2 - if it's a paying job, get the CNC shop quotes first and build that into the price you quote your client
My 2C
Howard
What Howard said.
Victor Parisian
Re: Unless my arithmetic is wrong....
Brian in Brighton
>Last I knew the heads of most cnc's are 90 degrees to the material. they might be able to drill is at an angle with a different kind of tool, but I would seriously doubt that they can, or would, try to drill down at an angle with a standard cnc spindle. Now, if they have a 4th or 5th axis, they can do it, but that machine will cost a lot more per hour or time.
Personally, I would consider offsetting 2 sheets of 1/4 inch pegboard the proper distance and put 1/2 inch strips to keep them apart. The holes would be thru. But it might serve the purpose.
Brian in Brighton.
Busy working and no time for lurking.
