Electrical Update - Learned some good things! long
Stephen Kirk in Quakertown PA
>Hopefully, a few of the things I picked up can help others.
I had my brother, who is much better at all things eletrical, come down to help me wire up some new circuits and receptacles. We discovered a few things:
1) I had 20A breakers but only 15A receptacles - while not the end of the world, it is a potential problem. If I would pull 20A through the receptacle, it could catch fire.
2) A garage is considered a wet environment, so I needed to add some GFIs. Put it at the start of each run and it can protect 3 downstream items. Alternate solution is to use GFI breakers, or make the 100A breaker to the sub panel GFI (nice, but very expensive)
3) I wasn't leaving enough spare wire in the sub panel - didn't need to fix right away, but good reason to junction with longer wires in the future. Very useful in case you need to move a breaker.
4) Larger boxes, plus receptacles with clamp connecters are way easier to wire up.
5) Klein makes electrical tools that will really simplify your life - the screwdriver that can bend a perfect loop is sweet.
6) Have a good working plan, such as mount all boxes, then run wires, then hook up each receptacles, then wire into sub panel. Makes the work go fast. Can help with the purchasing and limit extra runs to the home store.
So, I now have 4 new circuits, a 220 for the jointer with it's own special plug, a 20A with 3 receptacles (first being GFI), then 2 more 20A GFI circuits and receptacles mounted right off the sub that will serve as the start for future runs. It's enough for now. I also went around to all my tools and grabbed the volts and amps off each so I can make a chart which I'll leave in the shop to easily identify what things I can run together. After doing that, I'm amazed I haven't tripped breakers or fried any receptacles.
