Epoxy - The Wonder Product
Bart Goldberg
>Hi Fellow Dust Makers,
I don't know about you all, but I have found that I increasing use epoxy for many of my projects. I typically buy 2 part epoxy, like System 3, in gallon sized containers. This stuff never goes bad like Yellow glue can, although I sometimes need to warm the containers up a bit if they start to crystallize.
Some of the reasons I like epoxy:
1) Long open time - the System 3 brand I'm using has a 20 minute open time.
2) Strongest glue you can use.
3) Does not require significant clamping - Blue painters tape is all that is needed.
4) Does not require tight fitting joints - it will hold your joints together whether they are tight or loose fitting.
5) It acts a a gap filler. Related to item 4 above. In fact, I prefer it over wood fillers. I usually add some saw dust or dye to it when filling in gain, tear out etc.
6) Water proof.
7) Once fully cured, it can be milled and worked just like wood.
One question I have is - does anyone know how various types of epoxy products differ? I recently purchased from Lowes, some Locktite brand 5 minute, 1 to 1 ratio epoxy. While this stuff is great for quick fix use, it does not seem to have the strength of the 2 to 1 ratio, System 3 epoxy I typically use.
Regards
Bart
