Computer help Please.
>A few days ago my computer displayed a message the Config.sys was corrupted or unavailable. Said to use the Setup disk to fix it. That sis not work for me so I took the computer to the shop. Got it back today. Guy said the OS was reinstalled because they could not fix it. Also said they removed McAfee because it was "so corrupted" that I should reinstall it.
I have Windows XP Home Edition and use Internet Explorer.
Comcast cable makes McAfee free, so I use it.
I decided the first thing I should do was to install the McAfee virus. I stumbled around a bit and finally found it on the Comcast.net site, but it would not download.
Almost everything I put into the browser comes up instantly with the message "The requested lookup was not found in any active activation context." Many things do nothing. I also found that my "Favorites" are listed, but do not work.
I talked to McAfee on the phone, but they were no help. They wanted me to download a McAfee remover and be sure all of McAfee was gone, but I can't make it download. They said to call the store that did the work. Their answer was to bring the machine back Monday.
I suspect this does not have anything to do with McAfee as such. the problems started immediately and I just struggled with them long enough to involve McAfee.
Any suggestions?.
I just stumbled into Google Chrome and It let me come to WC. TIA
Re: Computer help Please.
del schisler
>just mo 2 cents Mcafee is hard to remove and use Not the best Cost's avg is not the best but free If you don't go to lot's of what i call not my kind of site's You only need Zone alarm and ad-ware and maybe spy-bot searth and destroy I have never had a problum If mcafee was good it should have keep comp from virus ?? you know you can down load fire fox also for a isp provider Now another thing i had I use xp I down loaded hijack this and I guess stumble into the do a system scan only and i put a check mark in ever thing It will repair what is needed Worked for me Something had me lock out of woodcentral and wouldn't let me come here After the clean Now it work's like it should Of course ever case if different As far mcafee goes you will have to go into reg. and look for anything that has that name Even the unstall will not get rid of it I wouldn't mcafee again No way If you use these you shouldn't have any problum Zone alarm and ad-ware and maybe spy-bot searth and destroy good luck del
Will Abbott
>Computer shop should have been able to fix the problem without a reinstall. McAfee would have been completely wiped out when the OS was reinstalled. So that is unlikely to be the problem. I would try calling Comcast to make sure that your web browser is setup correctly. The error message sounds like a DNS error to me. You may want to try and flush the DNS cashe and see if that helps. If that doesn't help, reconfigure the IP settings to Auto.
Ralph Lipeles
>I had ad aware and spybot on my wife's computer but a "friend" removed them while trying to solve a problem. I would like to reinstall them but cannot find a site where they are still free - without some related purchase. Do you know of a place where they can be downloaded for free? Thank you.
Spybot and Adaware
Chuck W
>just google spybot and adaware...should bring you to the appropriate webssites where the software can be downloaded.
Re: Spybot and Adaware
Ralph Lipeles
>The only problem is they only give a free download if you are making a purchase.
del schisler
>http://download.cnet.com/Ad-Aware-Free-Anti-Malware/3000-8022_4-10045910.html
http://download.cnet.com/Spybot-Search-amp-Destroy/3000-8022_4-10122137.html
here is both c/p them in location window it will take you right their open and run
Chuck W
>No. That is not true. Both offer free versions of their software.
Jason Roehl in Lafayette, IN
Make sure...
>That you get "Spybot--Search&Destroy" and "AdAware by Lavasoft". There are similarly-named offerings out there that claim to do the same things, but in reality are trojans, worms and viruses, the very things that Spybot and AdAware are supposed to eliminate.
Jason
