OT I hate plumbing.
Dustmaker Mike
>OK I feel better. One simple job of moving a sink drain in my half bath. So here goes I start yesterday measuring everything and heading to the BORG to get the correct size ABS pipe and fittings, while I was there I even picked up a PC hole saw kit to make sure I had the correct hole saw. I start this morning taking out the old drain because of the way they routed it. No problem everything comes out easy. I then go to do a dry fit and discover I need a 3 inch coupling. I head to the BORG again get the coupling head home. Drill the first 2 1/2 hole to fit the sink drain in the 3/4 inch floor no problem. Head down to the basement to drill the next hole in the 2 x 10. The hole saw binds once and that was the end of it. The center square in it is now round. Head back to the BORG to get a better hole saw. Spend the money and by a single Lennox 2 1/2 hole saw and new mandral. Get home go to put it together and find I grabbed the wrong mandrel. So back to the BORG for another mandrel. Did I say I hate plumbing(-;
