OT - Computer Question
Ralph Lipeles
>My current Dell Dimension C521 PC runs Microsoft Vista. However, there are not any Vista drivers for one of the printers that I really like, my HP 500 DeskJet. So, I was thinking of setting up a home network with my old Dell 4300 which will drive the HP printer. My question is, since I do not have any more connections on my 2 Wire Device, and the old Dell 4300 is not wireless, can I simply connect the old Dell 4300 to the Dell Dimension 521 with a USB cable to set up the home network?
Re: OT - Computer Question
Ed Beck
>No, that's not going to work.
The cheapest way out is probably to get a USB WiFi connector like the one in the link.
HOWEVER before you do that, check to see if you have an open USB 2.0 port available. If not then you'll either have to find a WiFi USB 1.0 or 1.1 connector or add a USB 2.0 card to your computer.
Re: OT - Computer Question *LINK*
Jerry Nicholson
>The linked HP site claims that the Deskjet 500 is supported in Vista. Since I don't have either Vista or a Deskjet 500, I can't tell you how to find the drivers.
Jerry
HP Vista Drivers
Will Abbott
>You can create a work group with the old computer and then share the printer on the Vista machine.
Ralph Lipeles
>What is a work group? How does it compare to a home network? How do I connect the various computers in the work group? Thank you.
Workaround solution.....
Chuck W
>Ralph,
This is not the ideal solution to make your printer work with Vista and is, instead, a workaround using Vista's built-in drivers....
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01655752&lc=en&dlc=&cc=us&lang=&product=59769
