OT Septic drainfield question
Dave LaPine
>Anyone out there with drianfield experience? I have been getting mixed answers my question by local septic companies. I have a low pressure distributon septic system. It has 1-1/4" pvc lateral runs in my yard that I think can be vacuumed out by a pump truck. Does any one know if this is correct and if so what sort of vacuum setup do they use?
Re: OT Septic drainfield question
>Whenever they have pumped my septic, they pumped (and rinsed) out the tank. The drainfield is left alone. The vacuum hose on the pump truck is usually quite large in diameter. The "nozzle" on the end of the hose is more than 1 1/4" though.
I don't know of anyone in my area who really goes after the drainfields. If you have a 2 compartment septic, the solids usually accumulate in the first part and then as the tank fills, flow out the outflow pipe into the drainfield.
John Veerkamp, Western Mo
>I've had a septic system for 30+ yrs. I've never heard of cleaning the lateral lines. As JL said, the only thing that should get into the latterals is liquids after septic digestion. Periodic pumping of the tank is pretty standard practice. Depending on the load and usage every 5-15 years. It does help to add digestive enzymes to the system. There are ones specifically for sluggish systems that are internded to flush out into the latterals. Any Hardware stoer or even the big boxes should carry a variety of products. Also plumbing supply houses. Beware of claims from unknown companies. This area is fraught with shams.
John
GalenV in Iowa
>Never heard of an in ground or at grade system to have 1 1/4" laterals so are you sure what you have? The normal head to an in ground is usually 5 feet and if a pumped at grade it is still set to pump to no more than 5 feet of head on laterals so they are all low pressure.
Agree with the others that it is normal to have the septic tank pumped out and cleaned before you ever get to the point it overflows to the secondary chamber and out to the laterals.
The type and amount of toilet paper you use can sure have a big impact on how often you have to pump! Use of a garbage disposal is another big factor.
Galen
Kneale Brownson..Packing for return to CO snows
>I used to install septic systems.
I've never heard of a drainfield plan using piping that size.
Your local county government, and possibly your state, set requirements for your drainfield components. They issue permits locally and inspect the drainfield before it's covered. Normally, your locally permitting agency (could be the county health department or the construction code office or a plumbing permit office) would have a record of the permit for your drainfield that would include a plan with component specifications.
Normal septic system service is just pumping out the tank(s). Most modern tanks have two chambers with two covers for inspeting and cleaning. A good system for a high-usage circumstance would have two double tanks. The multiple settling chambers is to keep anything other than liquid out of the drainfield. There should be no need to "vacuum out" the drainfield itself.
Dave LaPine
>Yes the laterals are 1-1/4" (believe me I know, I had to find all of the ends) In our area an older gravity system the laterals were about 4" but the newer LPD systems are 1-1/4". I had the original 10 year old pump replaced and it burned up 14 months later. They told me that my field was plugged and I needed to find all of the ends of the laterals, uncap them, then turn the pump on to clean out the lines. Only a couple of them had a small amount of yummy black goo in them but since I have them uncapped I wanted to see if the lines could be cleaned out better. It does not appear in several sample holes that the drainrock under the laterals is saturated or plugged at all. I want to find the problem before I burn up another pump.
GalenV in Iowa
>Dave
Guess I learn something new. What part of the country are you in?
With 1 1/4" laterals what size holes do the laterals have and could they be plugged even though the pipe is not?
Your regulations must give some guidelines on the pump capacity and head. Maybe with the small lateral there is too much headloss for the pump you put in as a replacement.
You're not in an area that is extremely wet this year and field just saturated so system cannot absorb your waste flow?
I've had more problems with the city sanitary waste system since I moved in town and away from a septic tank system that worked!
Galen
Dave LaPine
>I should know what size drain holes the laterals but do not since the holes are on the bottom side of the pipe. Maybe 3/16"? I'll have to get down in there to look. Exactly what you are saying they may be plugged and that is why I'm wondering if they can be vacuumed out. I'm in the Seattle area and believe it or not the ground is bone dry everywhere I have dug since we have had such a dry summer. I assume the $200.00 pump that the septic company installed and charged me $1,300.00 for is the correct one.But that's a whole other story.
Clint Searl
Clint Searl
>I have a similar system here in Haycock Township, PA, where the ground never percs. The drainfield lines are fed fron the second stage pump tank. If the outlet baffle in the primary tank fails and solids go to the pump tank, the pump will push the solids into the drainfield, where they will clog the drain holes. I doubt that trying to suck the holes clean from either the head or tail ends will free the lines.
Good luck,
Clint
A possible suggestion
Gary Camp, Bend, Oregon
>I also don't know of a vac system for 1-1/4" lines. There are two things I done to help the laterals though and yes I am familliar with the "yummy black goo". One is pretty nasty, but cheap. I have taken a piece of large diameter wire rope, 1-1/2" or so and unlaid a single strand and rodded out each line. The helix in the strand rubs the inside of the pipe and kinda clears the prefs, real nasty real cheap if you can find the wire rope. The other option is high pressure water jetting. I have guy that comes up to the "Rock Pile" where I work and runs a water jet through my problem drain lines every fall. the spray head he uses has a single jet pointing forward and several jets pointing out and back to pull the hose forward and clean the sides of the pipe. I haven't tried this on a drain field other than to clean the lines before TV'ing them, looking to see if we had a crushed pipe. I will use this system next time I have to Rod out a drain line rather than the cable method.
glc
