OT - dynamo hum ?
OT - dynamo hum ?
OT - dynamo hum ?
Mike Hamilton
>Winter approaches, darkness soon at both departure for work and arrival from. SWMBO's garage door opener had a bad light switch, so I replaced it (the kind of timed switch that looks like ignition points). Have reassembled it all and everything works correctly - BUT - there is a 60 cycle hum coming from the opener when the door is not moving. I don't remember this from before but also don't usually stand on a ladder near the opener. When I get right up to the opener on my side, there is also a hum but not as loud.
Any idea what's going on here?
Thanks in advance,
Mike
Re: OT - dynamo hum ?
>You might call the manufacturer, but my first thought is that there's something attempting to run when it's stopped; which would be bad news, leading to early burnout of some component.
But call the manufacturer for sure.
Mike Hamilton
>I'll look into that. The openers predate my owning the house and I've been here 23 years. They are from Sears, so finding the manufacturer could get interesting. IIRC, they have built in receivers. As they are so ancient, when the transmitters died, I bought new transmitters with receivers that are external. I pulled the original antenna from each but didn't do anything further to disconnect the original receivers. I wonder if those components are what is active/humming?
Thanks for the response.
Mike
Bill Howatt
>It could be nothing more than the laminataions vibrating on a small power transformer that provids perhaps 12V or so for the logic board. Maybe in fixing the switch there is better physical coupling to the sheet metal panels of the opener and they are vibrating a bit too.
OTOH, motors are known to hum if they are stalled. Hard to tell.
Bill
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>If it is only audible after the opener cycles, but not before, it could just be the filament in the light bulb, being amplified by the thin metal housing.
I don't think I would worry about it. However, I would suggest that you put a little white lithium grease on the worm gear while you are fooling with it. That is the weak link to those openers, and usually first thing to go.
Reminder...
Tony - Memphis
>Thanks for the reminder. I need to grease mine. I've already replaced the gears once (ten years). I'm hoping by greasing once in a while, I can avoid that again. No big deal, but I'd just as soon not!
Oh, I have several things around the house that hum. One of my X10 switches hums nicely.
Tony
BrianA
>Dynamo sat on the edge of the bed her eyes twitching and her face gone red.
AHHH Gotta love Frank!
Brian
Re: OT - a $40 bill ?
Mike Hamilton
>Yeah, I miss Frank a lot.
Andy Halterman: Colores de oto�o
>Third-zees on missing Frank.
Great talent taken away far to early in life.
Noon tomorrow is Frank on Friday. Stream available at wncw.org.
Andy Halterman
Wishin' for some of St. Alfonso's pancakes in Hendersonville, NC�
Re: OT - transformer is the culprit
Mike Hamilton
>Neighbor is an engineer at the local electric utility. He came over and gave a listen, told me not to worry.
Feeling better now (and maybe a little silly),
Mike
