Wood Screws
Wood Screws
Wood Screws
Hal Langerud
>I feel dumb to ask such a simple question, but here goes. I need to attach a butt hinge to a 1/4" x 1 1/4" lath. Where can I find such a short screw and who might carry them. I've got dozens and dozens of longer McFeely screws, even some short enought but the heads are too small.
Thanks, Hal (on the York River in VA)
Re: Wood Screws
Re: Wood Screws
>Your hardware store may have bins of individual screws (my local Ace does, and Lowe's and Home Despot in this area do), but 1/4" is awfully short (although the screw will be more like 3/8", since hinge plates have thickness). You may need to consider machine screws and nuts if you have the room behind the lath. Or machine screws and small T-nuts into the lath, if you can find any thin enough.
You realize, I'm sure, that you've got very very little strength from the lath.
Re: Wood Screws
Re: Wood Screws
Ed Mulligan, Cape Cod
>A quarter inch is pretty short.
If you can't find what you're looking for, take the shortest screw you can find and grind or file it to the required length. If it's brass, in other words soft, I can usually cut them with a wire cutter or similar tool.
Re: Wood Screws
Try a pop rivet
>...with a washer on the back side. Short screws will work to an extent, but, if these hinges are going to see a lot of action or loading, I'd go with something that won't pull out.
Re: Wood Screws
Re: Try a pop rivet
Lewis Dodd
>Ever consider glue. I have used "Goop" on all kinds of stuff and have yet to be disappointed.
Re: Wood Screws
Re: Try a pop rivet
Hal Langerud
>Thanks to all for the advise.
Pop rivets may work, especially with the washers. Maybe combined with the glue suggestion.
What I'm making is window covers for a screened-in deck. They probably will be closed most of the time so using lath should be okay.
I'm going the cheap route since they are for a retired neighbor lady and I want to keep the cost down. (My labor is free).
Hal.
Re: Wood Screws
Re: Try a pop rivet
Rob Lee
>Hi -
Ellis' suggestion is a good one - I've done this with cedar lattice before, and it works well!
Cheers -
Rob
