Need help with wood load rating.
davhamm
>I am building a ramp / platform, to drive my old car up onto. It is a simple structure one side is an 11' 2x12 laid flat with another one parelleling it supported by 11" 2x12 every 12". Think of a short wall using 2x12 instead of 2x4 and the studs on 12" centers. I think that should be strong enough to hold the car. the trick is the setup on the other side, as I want to be able to pull out the middle once the car is up. So, I have made shorter versions of the above 2 that are 2' long those will be the pedastals the car wheels stay on once up. THere is 7' between these. So I made another section up that is 3' long that can be pulled out.
Finally to the question I have 2 2' spans (between the pedastalls and the middle 3' section) These also are 2x12 Do they need support? or just sitting on the 2x12 on each end enough. In other words what is the load a 2' long 2x12 laying flat simply supported at each end can hold?
Can provide pics when I get home.
Re: Need help with wood load rating.
Section moduli and stiffness
>This answer depends on the wood more than anything else. Hickory or oak will have a heck of a lot more stiffness in that section than Hem-Fir or whatever your 2x12s are. Regardless, you need to be sure the bending moment doesn't exceed the product of the fiber stress in bending (species- and board-specific) and the section modulus of the beam. Softwoods, like framing lumber, have fiber stress quotients in the neighborhood of 9,000 psi or less. Oak and Maple, by comparison, are over 15,000 psi. If the load is centered on the span, the bending moment will be the weight carried by that wheel multiplied by half the span in inches squared. The section modulus of a 12 x 2 (a 2x12 laid flat) is only about 5, so if the product of that and your fiber stress in bending is less than the bending moment, you're going to need stiffer or thicker wood for your ramp.
I'm not an engineer; I've just built a lot of houses and things where these computations were important to know about. I'll let the engineers in the group clean up after me.
Dale Stansbery
>I think you're asking for trouble. The strength of the wood is the least of your concerns if the joints decide to fold like an accordian, especially when you're under the car. I'd suggest getting a 2 ton floor jack and a pair of good quality car ramps. You can drive the front tire up on one, then jack the car up and slide the second ramp under the rear tire. I've had all 4 tires off the ground this way. Make sure that you have the emergency brake securely set when it's up.
Re: Need help with wood load rating. *LINK*
davhamm
>Dale, sorry been away awhile. Did not mention that boxes are closed with chip board sheets on both sides to prevent racking.
One side is like this (one long peice) http://www.corvettec3.ca/ramps.htm
The other side is similiar box construction but the middle comes out like http://www.clubcobra.com/forums/showthread.php?t=61273
Anyhow mute point local lumbar yd closing picked up some 4x6's for .75 that I will slide under each bridge section, so I think I will be fine.
For some crude pics of what I have before the chip board. http://picasaweb.google.com/Davhamm/CarRamps?feat=directlink
