Making sure of the math...
>So if I have 480 bd. ft. of lumber, that would be ~40 cubic feet of lumber. Figuring on 45 lbs/cubic foot, that should weigh in at ~1800 lbs.
I realize that some lumber is denser than other lumber. I was just figuring on a low average for hardwoods. Should I use ~50 lbs/cubic foot?
Re: Making sure of the math...
Fred Davis
>You may be low at 45 Lbs, depends on whether it is hardwood or softwood and MC ,especially the last .
FredD
"Use" for what
Bill Tindall, E.TN
>What is the need? Are you loading a truck with this lumber, or a rack or you are curious??? The error in assuming 45 or 50 does not seem very important for any application I can think of. Whether the lumber is 5% water or 10% water will be an equivalent imprecision.
Completely wrong.....
Mark Goodall - ATL- tooljunkie
>You're not using the "New Math".
You need to determine how the wood will make you feel and how it will impact your life ;)
Happy Woodworking!
Loading a truck...
>If I get all that I want, it will be about 6700 lbs. I can't get that in the back of a F250. I can get a flatbed trailer, but my maximum towing capacity is on the order of 9000 lbs. So - I have to be judicious - I don't want to rent a truck unless I have to.
data, source NHLA
Bill Tindall, E.TN
>estimated shipping weight per 1000 bdft
oak green 5800 pounds
air dry 4200 pounds
poplar 4600 and 3200 respectively
the grade book goes on to explain that these are estimates because lumber will be cut to slightly different thicknesses, moisture content will be different and even the same species will weigh more or less depending on growth conditions. . But, these values are good enough to determine how much you can haul. I hauled 500 bd ft of 10-12' KD lumber easily on a 1/2 ton van, dozens of times.
How much you actually can haul will highly depend on how long it is. I have hauled 700 bdft of 8' lumber on a load (not too far to be sure). Don't try even 500 bdft of 16' lengths.
Re: Loading a truck...
Fred Davis
>If you can rent a trailer similar to the one I have which is a 16 foot flatbed with two 6000 lb rated axles , your 250 will haul that without any strain.
If your truck has a tow package and a 3/4ton generally does , so much the better.
Of course we are talking about electric brakes on the the trailer.
FredD
Tow package w/ transmission oil cooler
>and an electric sending unit for electric brakes and a Drawtite hitch.
Re: Completely wrong.....
Yonak
>Mark, I believe there are times when thinking more in terms of how breaking an axle will impact one's life is more pertinent.
Not easy to rent a flatbed trailer...
John in NM
>Though I think U-haul's got some little ones with sides. My wife's insurer won't even insure my flatbed truck! Same truck with a regular bed would be fine. Ironically, there's about six trailers locally, just like what Fred describes, that neighbors lend for the asking.
Re: Tow package w/ transmission oil cooler
Fred Davis
>Not to mention a Duramax diesel and a Allison five speed transmission, air cooler for the Turbo, four wheel disc brakes and so on. ;-))
FredD
Use this calculator online: *LINK*
Grant in Iowa
>Here's a handy bunch of calculators that I use regularly when I'm hervesting or moving large quantities of lumber around. Make sure you have an idea of the moisture content, as that can effect the final information greatly.
For instance, I recently moved 1200 BFt of red and white oak on my trailer to the kiln at an everage of roughly 17% mc. I used the White Oak menu choice and came up with 4706 lbs. Coming home from the kiln in a few weeks, it will be around 7-8% moisture content and weigh 4589 lbs.
Funny, I thought it'd lose more weight than that! I guess Dr. Wengerts math is probably sound.
You only need to enter the top three lines to get an answer, by the way. Choose the "Lumber Weight Calculator".
Regards,
Grant in Iowa
Woodweb calculators
Thanks
