Am I correct in assuming (or presuming)
Stuart Hough
>If the outside humidity has been high as a front approaches, and then we have rain for several days, am I correct in my assumption that if I machine tenons for the base of my workbench, I will find that they have shrunken a tad in width when I go to do the assembly in a week or so? I think might be better off waiting for a dry spell before cutting the tenons. Thanx for your advice.
Re: Am I correct in assuming (or presuming)
roninkokomo
>Has to do with the moisture content of the wood, not necessarily the ambient air... thought they are related.
Lee Grindinger
You are over-thinking this
Lee Grindinger
>The actual movement across the thickness of a tenon is not enough to worry about. Just keep working.
Lee
What Lee said.
>If I remember correctly you are using SYP.
You have maybe a 2" tenon at best? The wood movement would be on the order of what - maybe 0.05" at worst. That's less that 1/8". Put a chamfer on the end and use a larger hammer :).
Bill Howatt
>If it was important there would be a lot of woodworkers standing around looking at their hygrometers. The wood isn't going to react instantaneously to differences in the MC. When you slap on the white/yellow glue remember it is loaded with water and would literally swamp out any minor variations from the air.
Bill
Different take
Ed Mulligan, Cape Cod
>I think it is wise to keep an eye on the humidity and the relative moisture content of your wood, and take action if they change.
From experience, biscuits that have been exposed to high humidity are too thick to go into their slots. A trip to the microwave or an overnight visit in a warming oven gets them back to size.
In addition to dimension changes, moisture content affects cupping etc.
Hoadley recommends storing work in plastic bags if assembly is not immediately possible. I've read that some woodworking factories keep their work environment at a constant temperature and humidity to avoid problems. I know many luthiers do this.
I run a dehumidifier in my cellar shop during the summer to keep the humidity constant. I have a hygrometer in the shop to keep track of the relative humidity. If I'm making joints I make every effort to get them assembled quickly or at least keep the relative humidity constant while they are unassembled.
As always, thank you to all...
Stuart Hough
>for your insight. Ithink I'll get started!
Unjustified fretting
Bill Tindall, E.TN
>It is the fit for the thickness of the tennon that is most important for strength.
assume or presume -- an interesting question
Yonak
>Oftentimes the two words can be used interchangeably. According to Oxford Dictionary :
ASSUME : suppose to be the case, without proof.
PRESUME : suppose that something is the case on the basis of probability ; take for granted that something exists or is the case.
A jury PRESUMES the innocence of the defendant because there is no credible evidence to the contrary.
I ASSUME you're going somewhere because you have your car keys in your hand.
