OT---Repairing XP
OT---Repairing XP
OT---Repairing XP
Gary Evans -- Tallassee TN
>Hi all,
I'm trying to repair an XP installation that I did some time back. Problem is that it asks for the Admin. password in order to proceed with the repair. The admin password I wrote down when I did the original installation is not recognized. Is there any way to find the password that it's looking for or change the password to the one I want at this point?
A little history. Intermittent power issues on the previous computer that this hard drive was installed in have corrupted files to the point that Windows won't boot up. The boot sequence stops at "Verifying DMI pool data..." Hence the need for the repair. I could do a complete re-install, but I have a bunch of stuff on this hard-drive that I don't want to lose.
I have tried using this hard-drive as a secondary drive to try to get the pic's, etc., off, but Windows doesn't show the drive in "My Computer". I find it in the BIOS info in Set-up, as well as in the Device Manager, but I don't know how to access the data files on the drive without going through "My Computer."
Any help would be greatly appreciated. I'm sure my wife is getting tired of me using her laptop. 8^]
Gary
Re: OT---Repairing XP
wilbur
>Is there an optical drive (CD or DVD drive) on your computer? If so, one option would be to use a Linux LiveCD of some sort to boot up your computer, and then your hard drive should be mounted enough for you to access your files. Then you can do a reinstall.
The way this works is you make a Linux LiveCD using another computer, put it into the CD/DVD drive on your non-working computer, and your computer should boot off of the CD/DVD, just like it would if you put a WIndows installation disk in the CD/DVD drive.
There are a lot of Linux LiveCDs out there, but the more popular ones are Knoppix (http://www.knopper.net/knoppix/index-en.html) and Ubuntu (https://help.ubuntu.com/community/LiveCD).
Of course, if you have the Ubuntu LiveCD, instead of reinstalling Windows, you might want to give Linux a try. *evil chuckle*
Tony - Memphis
>When you tried the drive as a secondary in the other pc, did you make sure the jumpers were set correctly? Some drives require the jumpers to be set if the drive is a slave. Another option is cable select (ie first one on the cable is the master). Just a thought. I just lost my work pc, but fortunately, the hard drives were fine. Unfortunately, the new pc has SATA, so I am running the old drives via a USB box ($20). Good luck with it.
Tony
Tim Caley
>Go out to Google and do a search for XP password recovery to get the admin password back. There are plenty of utilities to get your password back.
Dan Donaldson
>If you have another computer, download an ubuntu install disk iso and burn it to a cd. You can boot from that, mount the hard drive and copy whatever you need off from it. I have done that a few times to get data off from a failed Windows installation so it could be wiped and reinstalled.
great minds think alike ;-)
Dan Donaldson
Re: reinstall
Chuck W
>I would go with a reinstall rather than patch up a corrupted file system. This is from experience.
>Actually, I have an Ubuntu CD. That sounds like a good way to do it if I can figure out how to make it work.
Gary
>I did have the jumpers set correctly. Like I said, the computer recognized the secondary drive. I just couldn't figure out how to access the files that are on it because it showed up everywhere except "My Computer."
Thanks,
Gary
>Good idea. If the Ubuntu proves to be too daunting, I will take a look on Google.
Gary
>Thanks Dan,
I hadn't even thought about Linux until Wilbur mentioned it. Luckily I already have an Ubuntu disc on hand.
Is there much of a learning curve involved with Linux? I used a Linux based network years ago, but I've slept since then. 8^}
Gary
>Thanks for the links, Curly.
I at least have more options now than I had several hours ago.
You have to love WoodCentral!
Gary
Re: reinstall
>Thanks Chuck,
If I can get my pictures and other files off this hard drive, I won't mind doing a complete reinstall.
Gary
Re: reinstall
Tim Caley
>If you don't format the hard drive during the re-install your data files will still be there. The install won't overwrite them. This will only work for data files, any applications you will have to re-install
Re: OT---Repairing XP *LINK*
Dan Donaldson
>You can probably google and get a tutorial on how to do exactly what you need to do. Here is one link that might help.
recover files from dead windows machine
Any Luck?
Tony - Memphis
>Let us know what you figure out. We'll all be there sooner or later. I try and remember to perform regular backups, but.....
Tony
Jim Cornyn - Chicago 'Burbs
>Sometimes a secondary drive will not automatically get an assigned drive letter - and so will not show up under your My Computer and you will have to assign a drive letter manually.
To manually assign a drive letter:
1. Right click on your My Computer icon (it cannot be a shortcut, it has to be the "real" My Computer icon - find it from your "Start" button if not on your desktop) and then choose "Manage" from the popup menu;
2. Click on the Plus sign in front of "Storage" to expand that area;
3. Click on "Disk Management";
4. In the right hand bottom portion of the Computer Management window you should see a listing of all of the storage devices that Windows is recognizing. You will see entries like "Drive 0" or CD-ROM 0" and an indication of the drive letter (C, D, etc.). For hard drives, there will also be a bar graph to the right of this area showing how the drive is formatted (FAT, NTFS, Unknown, etc.);
5. The drive you do not see in My Computer should show up but will not show an associated drive letter;
6. Right click on the "Disk x" portion of the drive without a drive letter and choose "Change Drive Letter and Paths;
7. Pick an available drive letter.
Opening My Computer should now show the drive letter you chose and you should be able to copy off the data you need.
Whew! There are a lot of steps here. That being said, you might want to pop for $20 or so and get an external USB drive enclosure as someone earlier mentioned. Install the drive in the enclosure connect it via USB and you should be in business.
Best of luck.
Jim Cornyn
Chicago 'Burbs
