Old router problem
Lewis Dodd
>What could be the reasons for a router collet to loosen and let the bit slowly descend resulting in a deeper cut. It is tightened up.
Old router problem
Lewis Dodd
Re: Old router problem
Stuart Hough
>Could be pitch built up inside the collet, allowing things to seem tight when you wrench it down, but allowing clearance when things heat up and the pitch softens. JMHO
Larry Clinton At Frankfort (Central)., Indiana
>I have had this problem with a Craftsman router (which I got rid of) I believe that router collet was just poorly designed or made. My Porter Cable don't slip - However you need to keep the collet clean and free of any oil. I would also remove the collet and clean the collet socket (end of the router shaft) with either acetone or naphtha, also check for and remove any burrs found on the outside of the collet and socket. Also clean the router bit shaft with solvent and remove any burrs. One other thing, be sure to "lift" the bit a 1/16 to an 1/8" off the bottom of the collet before tightening. This allows the collet to properly seat and also make a stuck bit much easier to remove. If you have tried all the above, you may just have a worn out collet. I have purchased several spares for my Porter cable routers. They are relatively inexpensive and I believe are available for most routers.
Re: Amen on the Craftsman problem
Glenn Madsen near San Francisco------WebKitFormBou
>A neighbor gave me one maybe ten years back. It went, fully disclosed, in a yard sale shortly thereafter. No more Craftsman tools for me. There's no need.
Only one other router ever did that to me, a Bosch that I was asking to take too big a bite in maple. Cleaned up, the tool worked properly in its range of use thereafter. I still check that one closely, however.
Fred Davis
>Bosch routers have well made segmented collets and having used them for a long time , never had that problem Glenn.
I wonder if your collet has a buildup of various materials like , sap , glue , pitch, oil, etc.
I suppose it's possibile that the collet is defective , you shouldn't have to crank on the wrench to get it tight and tightening it too much isn't good either.
FredD
Try an "O" ring in the bottom of the collet
Dave Bair, Eaton Rapids, MI
>A 1/2" or 1/4", depending on the collect size. It'll give you the space Larry mentioned without guessing.
Reasons
Lee Schierer - McKean, PA
>1. If you put the bit all the way into the collet so it bottoms out, the collet cannot tighten properly and the bit will most likely slip during use. Always leave 1/8" gap between the bottom of the collet and the end of the bit.
2. If the collet is not clean or if it has a burr in it, it will tend to loosen due to the vibration of cutting. I have a craftsman router and the bit has slipped once. I always run the router without cutting for a few seconds and then retighten the collet. I have cleaned the inside of the chuck with scotchbrite and that seems to have helped.
The only problem I continue to have with my craftsman router collet is that it won't let go. I have to tap on the bit shank to get the collet to release its grip.
Lee
>The problem with the Bosch Colt was too aggressive a cut in hard maple trim, and insufficient tightening of the collet.
In the words of my sons, who do computer tech support: The challenge was between the keyboard and the chair.
