Dealing with difficult veneers
Thomas S Stockton------WebKitFormBoundaryRU4sWQOIA
>Last year I had a bed project that called for walnut burl veneers, I had a few problems with bubbles in the burl panels. I was able to fix the problems but I wanted to find a better way to deal with difficult veneers like burls. This led me to Vacuum Pressing Systems excellent online forum. They recommend a process called 2 ply where you veneer a backer veneer to the burl to stabilize it. For my current desk project I used this process and it worked really well.
I flatten veneers using a commercial flatting agent, and then use my vacuum press to flatten and dry them. You can easily make your own flattening agent but I find it is easier to buy and have ups deliver it.
moisten both sides of veneer with solution
hang dry for 10 minutes or so
place between paper and cauls and press in veneer press. I use a layer of unprinted newsprint against the veneers and then add a couple of layers of newspaper between the unprinted paper
I change the paper three times the first day and leave under pressure overnight.
On the second day remove from the press and put in fresh paper. I don�t put it back in the press, instead I weight the stack on a flat surface. I change the paper three times and the next day it is good to use
Pic is of burls hang drying
