changing arrow heads in sketch up
McKay
>Is there a way to put the arrow heads on the outside of a very small dimension line so that the arrow heads do not write over the small line?
McKay
Yes
Alan Young
>Hover cursor over the dimension and right click. A drop down window gives you options of placing the number before-middle or after arrows.
Re: Yes
Alan in Little Washington (NC)
>How about changing (increasing) the size of the arrows and for that matter the size of text?
I find if I want readable labels and dimensions, I must reduce the size of the drawing before exporting the jpeg then blowing it back up in a photo-editing program in order to get decent sized text.
Same idea--
Alan Young
>Right click over the dimension figures. A drop down box appears-click on Entity Info-make desired adjustments.
Thank you, thank you!!!
>Fantastic! Where were you when I was doing a bunch of SketchUp drawings?
