time to wax after wipe on poly
Bob in Green Bay
>I have recently finished a piece of work using wipe on poly.
I dug back into the FWW magazines and found that you should wait one month to wax after a petro based sealer is applied.
Gee, I hate to say I can't wait this long, but it seems the poly is good and darn dry (6 coats) after about a week. I allowed 12 hours between coats
Any suggestions here? Will haste ruin the finish? I will use fiddes wax.
Bob in Green Bay - 27 degree last night
sanding will have to soon move indoors.
Re: time to wax after wipe on poly
Chuck in ND
>Poly never needs waxing.
>Good Evening Bob,
I am not a chemical expert. I do use wiping satin minwax poly the majority of the time on my furniture projects. Generally there are about six coats, applied on successive days, or when I get around to it. I never worry about wax application, because I never had a problem--at least one which I recognized. I like paste wax applied with 4/0 steel wool, which seems to make the satin gloss more mellow. I'm sure more knowledgeable people have good reasons to wait longer. I apply my coat(s) of wax when convenient. So far I received no complaints--and that may be that I only do work now only for me and for my kids. :<)
George
same here
Bill Tindall, E.TN
>I like to "wool and wax" most tops. I never waited that long, but then it is 70 here today not 30's.
The rate of cure for finishes is dependent on temperature. I can scuff sand and recoat a urethane varnish finish the same day when it is in the 80's, while it takes days when it is in the 60's.
Re: same here
al in two rivers, wi
>I have used wax over poly before, and had success. However, you really should wait for a couple of weeks after the poly is on to ensure a good "cure". Remember, poly is cured, not dried, like lacquer or shellac.
Bob in Green Bay
>the poly does seem a little too shiny...I used satin. It seems to make the minor defects more noticeable. A little wax with the wool may tone it down a bit.
I'll give it two weeks.
Even though its cold out - its about 70 in the house, probably in the 60's in the basement
Dave Bair, Eaton Rapids, MI
>I waxed all my kitchen cupboards within a week of the last application of poly. After two years in a fairly tough environment, the finishes look fine. I used Minwax poly and Minwax wax. Wax keeps stuff like syrup or peanut butter from sticking and makes the cabinets extremely nice to the touch.
