Installing Wainscoating
Lee Schierer - McKean, PA
>Our dining room has wainscoating that is made up of hardwood panels with a realistic wood overlay. LOML wants to get rid of that and install real wood. She likes the T&G beaded wainscoating with one beaded edge that our local hardwood supplier carries. Our walls are plaster over blueboard and the studs are 16" on center. The wainscoating comes in 2-1/4" widths. I know I can nail the bottom edge into the sill with long pin nails, but there is nothing at the middle and top to nail into. Here's the question. How does one attach this to the walls. I don't want to use adhesives to attach it to the wall. Do I glue up sections and only nail it every 16" where it is over a stud? Or do I nail it at the bottom and let the chair rail secure the top?
Lee
Re: Installing Wainscoating
>Normally, the boards are held in place with brads through the top moulding or chair rail that is nailed to the studs. The stock is shiplapped, right?
Re: Installing Wainscoting
Kneale Brownson..Awaiting return to CO snows
>How thick is your beadboard? I've installed the 1/2" thick stuff by first nailing up a plywood backer to nail the wainscoting to. A rabbeted chair rail hides the edges. If it's 3/4" stuff, I'd mark and cut out the blueboard to insert a nailing rail.
Additional Info
>The strips are T&G on the edges and they are 5/16 thick.
Lee
Re: Additional Info
>Lee,
With stock that thin, 1/4" or 3/8" play strips, top, middle, and bottom will do fine so long as you're going to use a cap moulding of some sort (which I would do in any event).
