"Easy Way" of Cutting a Perfect Hexagon?
Mark Meier (Ann Arbor, MI)
>I need to make 8 hexagons on the table saw. They will be cut from 3/4" melamine and will fit in about an 18" diameter circle.
Does anybody know of a clever sequence of cuts (or any other tricks) to make this as easy as possible?
I have a sliding crosscut table that I can set the angle on - so that part is no problem. It's just that once you start cutting the sides you no longer have long, straight edges to work with (you have shorter angular ones).
Thanks in advance for any advice,
Mark
Re: "Easy Way" of Cutting a Perfect Hexagon?
I know how to draw one, does that help?
>If you want one that fits in an 18" circle, Set you compass at 9" and Draw a circle. Then, with the compass still set at 9", set the point on the circle and make a mark in one or both directions one the circle. Move the point to that mark and step off another one, moving around the circle until you come back to the starting point. Connect the dot and you have a hexagon inside the circle.
So, You could take a piece of melamine and put two marks 9" apart on one edge. From each of those points, draw an arc, where the arcs intersect is the center of the circle. Draw the rest of the hexagon as described above. Using the the starting edge, it should be easy to cut them out on the TS. The angles are all the same, cut, rotate, cut rotate, Etc.
30 degree cuts=60 degrees per corner
Kneale Brownson..Awaiting return to CO snows
Ed Mulligan, Cape Cod
>Start with an 18" square piece of stock. Draw a hexagon on it. Set your miter gauge to 60 degrees. Make a stop for the miter gauge to support the 18" square so that the stop is more than 9" 'out' or long so it will support the work piece when angles have been cut on the side.
Adjust the stop so the saw cuts on your drawn line. Make cut 1. The side that's against the fence is one of your reference edges. The other reference edge is the opposite side from the current reference edge. Only these two edges are reference edges.
Flip the work piece so the face side is down and the opposite reference edge is now against the fence. Make cut 2.
Flip the work piece end for end so the side with the two cuts is against the stop. Same reference edge as cut 2. Make cut 3.
Flip the work piece so the current face side is down. Now the original reference edge is against the fence. Make cut 4.
Reading this, it's not really clear. Hope you can get the idea. If not, I will post a sketch.
>Hi Ed,
If you could post a sketch I'd really appreciate it.
Thanks!
Mark
>If the image is tough to see I'll send it via email. The beauty of this method is that the cuts register off only two edges, neither of which is formed during the miter process. You don't have additive errors that are possible if the work piece is registered on a mitered edge.
>Thanks very much for your input, Ed!
I will give it a try.
Mark
You're welcome!
