Eood Picker Damage
Eood Picker Damage
Eood Picker Damage
Don Philips
>A small wood picker keeps damaging the T1-11 siding on both my 30 year old garage and the 5 year old new building. What can I do to stop this 4 oz mobster.
Re: Eood Picker Damage
Randy Johnson Connersville IN
>You might try setting up a few owl decoys.
Of as much concern is WHY it is going after the buildings. You might want to check closely and make sure you don't have some kind of bug problem.
Doug Ridley
>Shoot him
Re: Wood Picker Damage
>T1-11 often has voids in the internal plies that translate into tunnels that run from groove to groove. Insects find them and either live in them or lay their eggs in them and leave. Wood Peckers can hear the insects and peck through the top layer to get at the insects/larvae.
I used to have a picture of the American Plywood Association's building (covered in T1-11, naturally) with aluminum pie plates hanging all over it to keep them away. So, either they did not have an answer or the answer is to hang shiny things all over that flutter in the wind.
Might have been possible to treat the plywood with one of the borate solutions to keep the insects out, but probably too late now. (It foes have finish on it, right?)
Doug Ridley
>I still say, shoot him.
Lee Schierer - McKean, PA
>Woodpeckers drill holes for two reasons. One is to get food. the other is to define territorial limits. The search for food is obviously year round, the territorial thing is usually only the nesting season. Check your siding, it may have an infestation of powder post beetles or other wood boring creatures that they are after.
We had woodpeckers attacking our treated lumber deck railing to get teh carpenter bee larvae that was inside the railing pieces. It looked like swiss cheese after I removed it with nice 3/8 diameter tunnels from one side from teh bees and elongated holes from the other side from the wood peckers.
Lee
Wind socks *LINK*
LGuthrie - Merrill, Wi
>Sometimes wind socks hung by the damaged area will keep them away.
T1-11 siding is famous for this problem.
It is illegal to shoot them, Migratory Bird Act
Summary - Migatory Bird Act
The Fix...
Kneale Brownson..Awaiting return to CO snows
>Mostly, I think, the woodpeckers spot the openings where plywood voids occur in the T-111's grooves, and assume there's bugs in there creating the tunnels.
I've reduced--and even eliminated--woodpecker attacks on that siding by caulking the openings and then painting. Hides the voids.
Have the same problem.
Gary Smyth
>as they peck a horizonal line of ten or twelve holes about four inches across perpendicular to the grooves. My problem was yellow jackets that made their way underneath. I sprayed powder Sevin at the yellowjackets entrance. When the yellowjackets went away so did the woodpecker. The bees are dead. No report on the woodpecker.
Cedar boards
Al Goldstein
>I had the same problem with some rough cut cedar boards underneath some second story windows. After filling the wood pecker holes several times I noticed some round holes on the undersides of the boards. Thinking wood peckers might believe these holes contained some food I filled them and stained the boards. End of problem.
Darwin
>implied that smarter birds (of any color) would not peck on MY house. We've had only a few dumb peckers, so the principal seems to be working.
Whatever
