Dust seperator 5 gallon
Chuck in ND
>I just finished putting together a small dust seperater useing a 5 gallon steel pail, drum, bucket, or whatever you want to call it, to use with a WAP vacuum for the small tools, such as a router table, mitersaw, disc sander, bandsaw, small sandblasting cabinet, etc. I went with the Thien concept.
Re: Dust seperator 5 gallon
Chuck in ND
Re: Explanation
Chuck in ND
>I'm sure some of you are asking why would he bother to do that when a shop vacuum isn't that hard to empty. There are a couple of reasons for me. The vacuum I'm useing has a cartridge filter and a paper bag filter inside it. I know the bag filters aren't too expensive, but still is an extra cost everytime I fill one up. Next is I think this will work good with the small sandblasting cabinet that I have, hopefully it will seperate the dust from the sand so I can reuse the sand.
Re: Explanation
BOB HAINES
>another nice collector fabrication - thanks for sharing
Re: Let us know how it works out, please.
Glenn Madsen near San Francisco------WebKitFormBou
Chuck in ND
>Just to try it, I grabed another 5 gallon metal can and lid, I'm going to try a side inlet in the side of the can, and the vacuum connection will remain in the center of the lid. I got a start on it this afternoon.
Steve Krieitler
>Nice setup!
I built a small cyclone a few months ago. It looks like crap, but works beautifully- and it's sure nice to not have to clean the filter on my shop vac all the time (I've cleaned it once since building my separator).
One improvement I would suggest is a remote switch on the end of the hose- with a long double hose setup, this saves a lot of walking. I accomplished this with a Christmas light remote set- a box that plugs into the wall, the vacuum into it, and a remote that I've fastened to the hose near the end, on a little nametag string reel. Cost ten bucks, and has sped things up in the shop quite a bit.
Chuck in ND
>Steve, the WAP ( Alto now ) vacuum has a outlet on it that I can plug whatever tool I'm useing into. When I turn the tool on, the vacuum will start and then will run for 5 seconds after the tool has been shut off to clear the hose.
Michael Wangler
>Chuck,
Nice job on the seperator. I built a similar unit but used a 40 gallon cardboard container. This allowed me to put my shop vac in a 'sealed' cabinet. This greatly reduces the sound and I only need to access the actual shop vac every 6 months or so to clean out the very fine cake on the filter. The shop vac operates very quietly in the cabinet..
Mike
Bart Leetch
>Put a panty hose top over the filter (legs tied off & cut short) & just snap it to remove dust.
Re: Dust seperator 5 gallon with side inlet
Chuck in ND
Chuck in ND
