REAL MILK PAINT
Need Free Toy Plans
Need Free Toy Plans
Need Free Toy Plans
Bob Hutter
>I'm looking for toy plans for members of our woodworking club to make toys for Childrens' Hospital in Dayton, Ohio. Club is Western Ohio Woodworking Club.
Re: Need Free Toy Plans
Not quite free
Lee Schierer - McKean, PA
>Get a copy of Norm Marshall's book "The Great All American Wooden Toy Book" It has dozens of wooden toys that can easily be mass produced. You can see some of them here: http://www.home.earthlink.net/~us71na/planes.html
and here:
http://www.home.earthlink.net/~us71na/vehicles.html
Lee
Ditto what Lee said
>I built almost all of the train related toys in his book when my son was growing up. The plans are easy to follow and most everyone with moderate skills can build them. If you have more skills you can improve on them.
Might be best
Dan Donaldson
>If you are going to mass produce them, you might want to get in touch with the author or publisher to get permission.
Re: Need Free Toy Plans *LINK*
Phil Joines Krum,Tx
>The 10 minute Toy Copyright Circe & Phil Joines
This car is designed to by fast and easy to make using the tools in our shop. We use a band saw with a 3/16� wide blade, 6� x 48� belt sander, 1� x 30� belt sander, drill press and a 1 �� sanding drum mounted on an electric motor shaft with an arbor adapter and Jacobs chuck.
We needed a car to fill an order from our daughter for 250 cars for the kids in her art class. We also like to make as many good looking toys as possible for the Christmas toy drives. For painted cars we use cut offs from 2x4�s although for clear finished pieces a dark wood like walnut or mahogany looks better. We get hardwood cut offs from several small manufacturing shops in Dallas. On this particular order we lucked out because Kim wants her kids to paint and assemble them.
1 Make a template from hardboard, �� plywood, etc.
2 In marking the stock align the template with the bottom of the car toward the center of the 2x4. Layout a second car opposite the first allowing 1/16� or the width of your saw�s kerf between them.
3 Cut the outside contours of both cars. Cut down between the cars to separate them.
4 Sand every thing except the cockpit area with a stationary belt sander. We use a
220 belt. It�s fast enough and leaves a finish that good enough for painting.
5 Make a jig to hold the car aligned on the drill press table to drill the holes for the axles. Ours is just a piece of �� plywood with a block glued on to form a right angle a little longer than the bodies. I hold them against the block by hand. Hold the same side of the car down on the jig when the two holes are drilled. That way the axle holes will be aligned to each other. If the sides had any taper introduced during sanding, and you change which side is against the jig between drilling the two holes, the wheels won�t all touch the ground at the same time. Use a 15/64� drill, the �� axles are a bit under sized.
6 Sand the cockpit with the 1� wide belt sander.
7 Because these cars are for little kids we break the sharp edges with the small drum sander.
8 There are all kinds of ways to finish them. As I said, for most the these we get to let the kids do it. The rest of them Circe paints with acrylics. She recommends sealing the wood with lacquer first so the paint won�t run. If you want to use spray paint give them a coat of Sanding Sealer first. It will seal the wood so one coat of spray will cover instead of 5-6. We use black leather dye to color the wheels. It�s a lot easier than paint and looks better.
There it is. I guestimated that it takes us about 10 minutes to do the wood working part of each car. The painting can take an hour or more depending on how fancy you get.
These cars may not be made for sale without our written permission and these instructions are not for publication by others.
We get the wheels and axles from Woodworks Ltd.
Have fun.
wheels and axles
Frank Ierardi
>Woodworkers for Children Charity, Inc. provides free toy plans to individuals and organizations making toys for charitable purposes. Pictures of the toys may be found on our web site www.woodentoy.org. If these are the type of toys you are interest in, contact me for free plans.
