Cracked Stair Tread
Cracked Stair Tread
Cracked Stair Tread
Kevin MacLuskie
>I'm making stair treads for my addition and noticed on one of them some cracks on the end after I routed it. I looked at the rest, and found one more that I haven't routed yet that has some cracks in it. If this were a piece I was turning, I would throw some medium CA on it, and keep on going. Is that acceptable here? Or is there a better solution?
Thanks
-Kevin
Re: Cracked Stair Tread
Dale Lenz
Dale Lenz
>If the cracks, voids, are large enough to hold epoxy; I use "blacken" epoxy, will look like a mineral stain in the oak. When sanding to level off the epoxy, if you develop some pin holes, I'd use the super glue to fill them. Might need to make two application of the epoxy on corner, curves, as the epoxy will flow down hill, use masking tape to made a damn.
Bart Goldberg
Bart GOldberg
>I Agree - Epoxy works great and can keep the crack from getting worse.
Mix with some fine saw dust and the repair will be very dark compared to the oak. This will make it very un-noticeable.
Bart
>Good Afternoon Kevin,
I would be inclined to use another tread or two, if only for appearance sake. I think using crack(ing)lumber for stairs is asking for trouble.
George
Ditto.....what the Col. said!
Frank Mutchler
Kevin MacLuskie
>Yeah, making new treads would be the best solution, and I can do that for one of them, but I don't have enough extra to remake 2. (I already use the one extra tread I made ahead of time due to a mistake cutting the length)
Kevin MacLuskie
>Thanks, I'll give it a try.
Re: Ditto.....what the Col. said!
Fred Davis
>makes three
FredD
JMOHNIKE@PSNW.COM
>Are you treating the symptoms or the cause. Filling the cracks may be only a temporary fix, as they may continue to open up. If the wood is starting to cup or warp the damage will continue, and it will have to be replaced at sometime. It is better to make a new one now. If you replace it later you will have one step bright and new with the others looking older and worn, which will mean a refinish job on the others to get them to match.
Just a thought.
Joe
