Router sparking
Router sparking
Router sparking
Thomas Norton
>I posted last week about router repairs. I had the commutator turned/polished at a motor shop. I bought and installed new bearings and bought new brushes yesterday.
But I am still getting a lot of sparking inside the motor housing.
Any thoughts? My father-in-law gave it to me years ago and I would like to keep it going. BTW it is an old Black & Decker.
Re: Router sparking
Re: Router sparking
Larry Clinton At Frankfort (Central)., Indiana
>It may be that the brushes are just seating in. Often when brushes are replaced they only contact the armature in a small line or spot. The armature may also have some "high spots" Due to the small contact area and brush "bounce" a lot of sparking may occur. After running for a while the high spots burn and wear off both the armature and brushes and the brushes "seat in". Then the sparking reduces or quits - In the motor repair shop I worked in many years ago we would (if safe access was possible) help this by pressing a craytex (rubber abrasive stick) against the armature while the motor was running - use caution as the stick can be caught in moving parts. Otherwise I would just use the router a while and see what happens.
Re: Router sparking
Re: Router sparking
GalenV in Iowa
>I assume you got OEM brushes so they are the right grade of carbon brush, size and length. Same spring compression. The grade may be marked on the side of the brush to compare.
If OEM they should match what bevel or not the brushes should have.
They will arc to a short degree to wear in.
Worst case is a short in two of the windings. Many times for high speed it would also have what I call a "knocking" sound. Caused by a change in push of the armature.
Not sure if the person that ground the commutator checked for shorted windings.
I have an old B&D but probably not the same model. I could check mine to yours if you list model.
Galen
