Jig wood?
Jig wood?
Jig wood?
>Rather than sacrifice my piece of 3/4" oak plywood, I went to HD in search of wood for jigs. I walked away as I was not pleased with any of the possible selections.
Which begs the question - what do ya'll use for wood for jigs?
TIA
Re: Jig wood?
Depends.
Forrest Addy
>What material to use on jigs depends on whether the jig's life is measured in minutes or years. Single use jigs are made from scrapbox material and cheap stuff. Jigs in ddaily use warrant more attention to materials and often justify spending the money necessary to ensure precition and performance.
Throat plates are a good example. They're partly sacrificial; you get a couple or a dozen uses out of them and demote them to use with the dado head in wider and wider setting until it's more lole than plate. If you buy them you're a fool; they're cheap and easy to make.
Zero clearance throat plates are exposed to saw flutter and wear which means the clearance is soon finite not zero. Recutting with dado heads and miters etc results in a definite consumption of throat plates so it pays to make a dozen at a time. Still you want good fit and accuracy in the throas plate so you be well advised to make them of a good grade of plywood.
Sleds are also sacrificial in a sense. Overcutting and use with other than a plain saw blade soon compromises the crisp edges resulting in rougher edges on the work. You make the sled also of a good grade of plywood bearing in mind that you will have to refurb/rebuild/replace your tablesaw sled. Drill press table jigs, dovetail jigs, drilling angles, cauls etc all will see wear and material loss. It makes sense if siginifcant time is spent in making a jig the parts subject to wear and overcutting should be easily replaceable.
You will never, ever find "good" plywood at the big box store. Cabinermakers and furniture makers don;t shop there. Shop for it at a lumber yard serving the fine woodworking trade or specialty plywood houses.
Re: Jig wood?
Re: 1/2" MDO, MDF, or BB ply (EOM)
Grant in Iowa
Re: Jig wood?
Your first mistake
>was going to Home Despot. Less than five miles from my local Home Depot, where the plywood looks like Pringles, is a contractor's lumber yard, where the plywood looks like parts of the Great Plains without the crops and farm buildings - that is, pretty darned flat.
