Re: Water Stained Teak Veneer
Ed Mulligan, Cape Cod
>The white haze is moisture trapped in the finish. To eliminate the haze, you have to let the moisture out.
First, clean the top with clean cotton rags dampened with naptha. Your local paint or hardware store will have naptha. Change rags frequently until they no longer bring up dirt.
There are commercial white ring removers available. Liberon is one brand name. Or, use denatured alcohol. Don't use rubbing alcohol; it contains water.
Moisten a clean rag with alcohol or ring remover. Wipe on. Let it dry for several minutes. Repeat as needed until the ring is gone.
You can also try warming the surface with a hair dryer. Heat softens the lacquer finish, allowing moisture to be released. Warm is the key word. If you get it too hot you will cause damage.
If the surface has deteriorated, there will be some residual haze caused by light dispersion due to rougher texture. This can be removed with car polish which is a very fine abrasive. Caution: This might make the spot more shiny than the rest of the surface.
When you are satisfied, wax the top with paste wax, also available at hardware stores. Hide the teak oil! It's the wrong stuff to use on an indoor table.
