How to hand plane very thin stock?
machinist60
>I have been making oval shaker boxes. The one problem I have is holding the box side stock while planing to thickness (anywhere from 0.060" to 0.090") after resawing on the band saw. Placing the stock on a flat sandpapered planing board works fairly well. The problem is that unless very careful cleaning is done to remove grit from the flipped over surface, the iron edge is damaged. This inevitably happens sooner or later resulting in a trip back the the sharpening stone or ridges which require extra finishing.
Perhaps someone has a better method to hold this thin stock.
Any suggestions welcome, John.
Re: How to hand plane very thin stock?
>You want a flat board on which to plane. You might, then, drive in brass or aluminum brads so they just poke up above the board's surface, and use them as stops against which to place the board. Or glue on a piece of wood ever so slightly thinner than the finished thickness of your boards.
Of course, use a very fine setting on the plane.
Jim Shaver
>Double sided carpet tape, works for me, I tape my stock to a piece of plywood and plane away... I also make Shaker boxes.
Take care,
Jim
>I've used some shelf liner material that the LOML picked up at HD. Sort of has a "waffle" texture. We found that it "gripped" the shelf contents too much. It sure grips wood well. I use it for routing also.
same here... and more detail
Bill Tindall, E.TN
>one piece on the trailing end of the strip works. You want the thin piece under tension not compression.
machinist60
>Thanks guys for the suggestions. Next time I have a bunch to prepare I'll try the double sided carpet tape.
John.
