Help!!! Planer Blade Sharpening
Marvin Horn
>Made my first blade change on my 15" planer a few weeks ago and and have been trying to get the old blades sharpened since. Luckily I had purchased a spare set with the planer so I'm not out of service.
First off, I was amazed to find out that sharpening ran from about 50% to over 100% of a new set of blades. Anyway sent them out and they came back with a concave grind of over 10 thou. in the blades. Called the shop and they said send them back and they would regrind for free (whoopee) ---when they return from vacation.
Got the blades back again today and they are indeed ground straight but blade to blade width is 0.849, 0.866 and 0.943 inches. When sent out initially they were nominal 1" blades and had only the most minor nicks in them, nothing that showed up in the planed boards. Have no idea why they ground them down that amount.
The Grizzly manual says to insure all blades have "equal material removal"
Called Grizzly for a blade spec for blade to blade variation and minimum blade width but they need a day or two to respond. The tech told me 0.004 blade to blade but he seemed unsure if this was really blade to blade on just for each blade. Found one reference here at Wood Central for 0.003 "straight and parallel"
Does anyone here have a good spec for blade to blade variation in width ??
With shipping charges mounting up I'm rapidly approaching the cost of new blades.
Re: Help!!! Planer Blade Sharpening
Dick Coers
>Can't help with the amount of material question, but I would sure change shapening services. I use a shop in East Peoria, IL. They do a bunch of paper cutting knives in long lengths. They put a straight edge on a 16' long magnetic chuck, and sharpen all the knives in one shot. All the blades come back within a couple thousandths. Cheap too. Something like $25 for your blades. Shipping might make it too much for you. Look for a shop that sharpens paper knives in your area. Private email me if you want more info.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>You would have been a lot better off honing that initial .01" off by hand, if you think that amount is not acceptable for your level of accuracy.
Now your greatest concern ought to be the difference in weight between blades. My bet is that your planer will have a lot of vibration when you put these blades on.
You can find a good article on out of balance forces over in the archives of woodweb.
Jesse Cloud
>Drop by a cabinet shop and ask where they get their blades sharpened. Chances are there is a good, reputable sharpener near you. I use Precision Sharpening here in Albuquerque and have never been disappointed.
david in indy
>this won't help with the badly ground blades, but I have listed in the classifieds a set of unused 15" sharpco (Canada) blades or if you want to simplify changing blades, a 15" dispoz-a-blade system.
unfortunately a common problem
Bill Tindall, E.TN
>What you experienced is a common problem with many plane blade sharpening services. Next time send to Misenheimer in Morristown, TN. They sharpen for the furniture factories and can do blades 36" long, precisely.
As far as how uniform they need to be, I don't know.
Jim Hoeller
>If you can find a someone with a Tormek and the fixture for sharpening planer knives, get to know him or her. I have been using the Tormek combination for several years and it can restore the knives to like new condition. It isn't fast and requires patience but the results are worth it.
