Dust frame question
Dust frame question
Dust frame question
Terry Alexander
>This may not matter....but.....
Most dust frames are rectangular in shape.
Let's assume we have a dust frame 15 x 24.
Q: Does it make any difference which side gets the groove and which side gets the tongue?
Like I said....probably doesn't make any difference....but I don't really know.
As always.....TIA
Terry Alexander in West Texas
Re: Dust frame question
Doug Reynolds in Seattle
>If the sides are solid material I would make the tenons in the sides and the mortises in the front and backs. Glue only the front tenons and mortises and leave the rears free to expand and contract with the movement of the sides. Probably do it the same way even if the sides were frame and panel or plywood.
Re: Dust frame ?
Chuck in ND
>Never heard of one. Please clue me in.
Re: Dust frame ?
Terry Alexander
>In "older" furniture making styles, I.E. before drawer slides, a dust frame was put between the drawers so the drawers could slide on them. I am just guessing that at one time the dust frame was a completely covered area instead of just being 1x3's.
HTH
Terry Alexander
Re: Dust frame ?
Fred Davis
>When I make a piece of furniture, I always put dust panels between the drawer for0r the reasons you stated.
Whether you glue the back rail to the side pieces depends on your approach to the expansion and contraction issues.
I glue all of the panels together and run a finish rail the same thickness across the front and dovetail the ends of that rail to the side of the piece, so all of the expansion will go to the back assuming there is any.
That may not work with what your making , but it is a superior method to incorporate in your next piece.
The major movement is always the side and top of the piece when it is done in solid wood, not the dust panel.
FredD
Re: Thankyou
Chuck in ND
I Do It That Way, Also
