Delta unifence rail question
HeatherA in AK
>Hi, I have a delta unisaw with a 50" fence that I am getting up and running. The 50" fence is too long for most everything that I intend to do (I usually hang out on the turning side) but I hate to just cut it shorter. I want to get a 30" rail but the only price I see is $265 for the rail for unifence model 34-897.
www.ereplacementparts.com/delta-34897-type-unifence-parts-c-3275_13780 _13922.html -
I see the fence for the newer U30 model is less that $100 (36-130). Does anyone know if the old and new style are compatible?
Thanks,
Heather
Re: Delta unifence rail question
Jason Waters
>I would do everything I could to make that 50" fence fit in your shop.
I know that's not the answer you want to hear, but I have a 50" Bisemeyer I got on a deal (with my saw!), and considered cutting it. 8 years later I am glad I did not!
Don't mean to second guess...
>... but if you plan to keep the fence and just want shorter rails, why not cut the rails you have? If you buy shorter replacements, you'll be inventorying the longer ones forever, unless there's a market for them.
Just a thought...
Bob Entwisle in NJ
>Here's an idea, (Ellis/moderators pull this if it violates the classified's rules) Post your 50" rails in the classified's to trade for 30" rails, I bet there are more than a couple of folk with 30" rails that wish they were 50"
Just a thought...
new and old rails are different
Alan in Little Washington (NC)
>The newer Unifence rail uses a different aluminum extrusion. The difference only affects the way it mounts to the saw top, not how the fence casting attaches or how the tape and cursor work (see photo). The newer extrusion is much easier to mount to the saw.
Suggestions:
1. Cut it down, and if you ever need the full 52" capability then . .
a. Attach the cutoff to the remaining piece with a good, tight hinge, and attach a folding leg under the end to support it.
b. Alternatively, make a 12" long, snug fitting "loose tenon" from hardwood or metal that fits inside the unused extrusion void. Use set screws or a good strong spring latch to hold both halves together.
2. Buy a new U30
3. Advertise a swap on various WW forums.
Doug Ridley
>There is one on Ebay for $75.00
HeatherA in AK
>Thanks so much for the responses. The picture is just what I needed. I have posted a wanted add on craigslist. Shipping to Alaska would probably be to much for a trade. I like the idea of using a block or hinge in the unlikely event that I would need the longer fence.
Thanks again,
Heather
