We value your privacy.
I need to bore a 1 1/2 inch hole in the bottom of a 6x6 post that will be 12 inches deep. The question: would you drill a pilot hole and then a spade bit to accomplish this, or just go with the spade bit?
>The smaller diameter bit will tend to wander off to the side - drill it in one step, but, I would use a forstner bit, it will go in with better control especially if you're drilling them by hand.
>i would do with spad But i don't belive they have one that long You could use a extention on it I wouldn't drill 2 holes the spade won't follow a little hole unless you try a small bit than they don't make one that long so back to square 1 Got a dummy piece ? good to try on it first ?
>Get yourself an aircraft bit, say 1/8" diameter by 12" long. Use this to drill your pilot. Then follow up with a spade bit on an extension. The center nib of the spade bit will follow the pilot hole.
>I'm not sure the pilot on a spade bit does much to control its direction once the bit is in the wood - even with a conventional spade bit, I've been able to "steer" the bit into a mild curve. I think it's the sides and cutting edge that are controlling direction. The pilot serves mainly to start the bit and hold it in place until the cutting edges are fully engaged. This is not based on any scientific understanding or deep expertise; just my sense from my experience. Thus, I don't think drilling a "pilot hole" would necessarily help you much.
You can get 16 inch spade bits, though getting one in 1-1/2 inches diameter may take some searching.
Another possibility is a ship auger - see link for one example, and remember that, if you decide to order from Lee Valley, do it through the link at the WC marketplace to earn Ellis some advertising income. The weakness of a ship auger is that it relies heavily on the screw center to work it through the wood, and screw centers don't always grab in end grain.
With either of these solutions, you should consider making a "cradle" to hold the bit in alignment. A chunk of 2x4 notched out appropriately and fastened to the end of the timber might be enough for the ship auger; the spade bit would want something a little more elaborate, with enough room for the spade part to contact the wood while the cradle centered the shank.
You also want a big, powerful 1/2" drill.
Ellis referred to an "aircraft drill bit;" I never knew that was the official name. I have always just thought of them as "12 inch long twist bits." Any good hardware store should have them.
