Drop front hinge hardware
>What is your preferred drop front hinge hardware? Or secretary desk hardware if you would rather call it that.
The span of the shelf or drop would be about 30" or so. I was figuring on using the secretary hinges (combination hinge and drop front support) for the sides and a couple of the single pin hinges for the middle.
All are available from Rockler and others for not too much.
Any other thoughts?
TIA
Re: Drop front hinge hardware
A.J. Hamler
A.J. Hamler
>Hi JL...
It really depends on the design of the secretary desk you're considering making. Is it a reproduction, an original design, or something you're doing from a plan? Plus, what looks good to you personally?
I recently made a field desk -- a forerunner of what we now call secretary desks -- and used simple brass hinges mortised into the frame. Here's what it looks like:
[IMG]http://i499.photobucket.com/albums/rr355/ajhamler/Deskclosed-lores.jpg[/IMG]
[IMG]http://i499.photobucket.com/albums/rr355/ajhamler/Desklower-res.jpg[/IMG]
The hinges are very solid and hold the drop-down front securely. The design of my field desk takes into account that the drop-down front is supported by whatever surface the desk rests on, so I didn't worry about additional drop-front support. However, I'm familiar with the ones you mentioned, which might work well for your application. The bottom line is what use will your desk see, and what look best appeals to you?
A.J.
>Good Evening JL,
I used these hinges almost in desperation when I built my #2 daughter's secretary desk. Ones purchased for the drop lid were formed with the barrel on the ventral side of the hinge straps. That meant that when the lid was closed up upon the desk front, the back edge of the lid would be displaced upward equivalent to the diameter of the hinge barrel. Hence there was a gap below the closed lid, and the top of the lid would close too high on the sloped sides.
Bear in mind that the beautiful new brass hinged I had bought had already been morticed into the cherry desk top and inside lid. At the time, I could not find the correct hinge anywhere. They all seemed to have ventrally formed barrels, rather than barrels central to the plane of the open straps.
I remembered a set of used brass hinges of the proper configuration which I rescued some years before. I stripped them of paint and polished them, and installed them in a replacement desk top and lid. PITA. They work very well, but were slightly larger than I would have preferred.
Don't know if this info will be helpful to you--I hope so. It may give others pause to consider their own hardware application. Good luck.
George
Profile View
>JL,
These hinges will support the lid without the lid bottom supports being extended. However, my grandsons like to emulate monkeys and swing on things. The bottom lid supports were part of the original design, and prevent catastrophies.
George
Lee Gordon
Lee Gordon
>So AJ, are those pics from a new book or somethin'?
Thanks, Colonel - what sort of span?
>That looks to be greater than 24".
>Thanks for the pictures. That's an interesting idea. But I'm looking more for something that will support the "desk shelf".
Re: Thanks, Colonel - what sort of span?
>Good Morning JL,
I just dug out the plans. The width of the desk lid is approximately 31 1/4". I don't remember the distance between the hinges, and the desk is in Silver Spring MD so I can't measure it. The pix shows the internal span and hinge positions. The cubby arrangement was yet to be installed when this pix was taken. Shop Shot 810 applies.
George
Thanks.
woodturner
>I had a similar problems with the hinges I purchased from Paxton.
I sent them a note and did not even receive the courtesy of a reply.
Here is an excerpt of the note that I sent them ..........
TO: Paxton Hardware
PO Box 256, Upper Falls, MD 21156
Regarding: Poor Quality
Solid Brass Hinge And Lid Support
Part Number 5008
I recently purchased a pair of these hinges to complete a present for my wife. I was surprised by the overall lack of quality.
The both hinges varied greatly in the tightness of the lid support. One hinge has enough play that the support brace can move side to side by approximately 1/2 inch when measured at 50% closed while the other is about 3/8" at the same position. .
The hinges were designed without centering the hinge pin on the center of the hinge strap. This allows the hinge to describe an arc when closing the lid. The lid will walk away from the front of the case instead of lying flush. Two simple bends during the manufacturing process would alleviate this deficiency.
The screws while nicely polished varied in length, some had damaged heads and many were missing the points which made them impossible to start. An additional concern was the overall length of 3/4". When mounting the hinges in a mortise the provided screws will protrude if the desk is made of 3/4" stock. I purchased 5/8 brass screws at the local hardware and solved that problem.
