Lacquered furniture repair
hamish macallister
>I have a client who's bed was scraped and chipped by some installers and i need to patch it. The bed is cocobolo and oak, w/ a maple/cherry stain tinted into the (what I presume to be)lacquered finish. I need to know what kinds of stains will mix w/ lacquer and also, any tips on this kind of touch-up would be greatly appreciated.
Re: Lacquered furniture repair
Ed Mulligan, Cape Cod
>I would approach this in different ways depending on the size and location of the damage. Can you provide that info?
hamish macallister
>all chips are small, 3/16x3/8, 1/8x1/2, etc. there are 5 in total, all are on the footboard at the top, high visibility. top corner of the leg on side is a cocobolo laminate chipout, that'll be the toughest I think. 99% pos. to be lacquer, manufacturer is no more.
>Hamish,
Invisible repair is not easily explained or learned. Your cheapest and safest option is to sub it out to a pro.
If you are doing this as a hobby for a friend and don't mind spending a lot of time at it and your friend doesn't mind a potentially botched job, then proceed.
Any oil-base stain will be compatible with solvent lacquer. Also, universal colors, powdered pigments, Trans-tint dyes, and there are many more choices.
I usually use shellac in place of lacquer for touchups.
If at all possible, and especially if the ding is highly visible, I refinish or reveneer an entire surface instead of touching up.
I don't have a recommendation for a link or book to read to get the basics of touchups but I think that would be a good place for you to start. If you then have questions you can always come back with another post.
Good luck!
>Check out Mohawk for furniture repair. Google them. They sell all the stuff, so you might get some useful info from their site.
hamish macallister
>why do you use shellac instead of lacquer for touch-ups? I originally thought that it would be easier to refinish. I'm a confident and competent furniture and finishing carpenter, but I've always stayed clear of lacquer because of the high voc content. the finish on this bed is lacquer, so I feel bound to it. I have oil based stains to tint the lacquer w/ but my prob. is that they don't seem to mix easily. they tend to turn the lacquer into sludge. I was hoping there's a trick to mixing it, but it wouldn't hurt my feelings to try a different product. any hints in this direction?
>Shellac has lower fumes, as you note. Also, it sticks to almost anything, even silicone contamination (usually). It's compatible with water-base stains. Works well with a fine brush. Dries slower which is a plus if the repair is larger than a pinhole.
If the area you are repairing is large, you might be able to see the difference between a lacquer repair and a shellac repair. But for little stuff, there's no detectable difference. Shellac will be a little softer, but again not a problem with small areas. Problems with sheen differences can be finessed with various grades of sandpaper and rubbing compounds.
For tinting lacquer or shellac, look into Transtint dyes I mentioned in my last post. They are excellent. Search this forum for testimonials. Go to Homesteadfinishing.com (sp?) for the most complete selection. Mix a lighter color than you need, and build up to the right tone, then top coat with clear.
Fred Davis
>Furniture refinishing especially the people who do Piano refinish and ding repair is a acquired skill that a highly skilled cabinet maker or furniture maker wouldn't necessarily have.
These people do ding repair that is invisible,because that is what they do , anything less looks just like anything less.
Barry has a good notion about Mohawk , it is always a good skill to acquire even if used infrequently.
FredD
