OT Question for the Arborists among us.
>I have a Redbud Forest Pansy that has a nearly vertical split in a branch union. The base limb is about six inches in diameter and the two leaders are about four inches. I put a nylon strap across the two limbs and wound it up tight about a year ago. It seems to be healing, but I was not able to pull the joint tight. Should I put a bolt through the split? I really hate the idea of putting metal in the tree, but other wise it will fail when the strap fails. (Right?)
If this fails the tree will be severely misshapen.
Any advice would be appreciated. What type of bolt? What metal?
