OT Stanley Roofing Nailer Leaks
Kneale Brownson..Awaiting return to CO snows
>My well-used coil roofing nailer (current model called an RN46) has started leaking air from the area of the trigger. Very frustrating to have to keep plugging in the hose when I'm trying to get a shed roofed before the next rain.
And, of course, it's the weekend so local repair shops would be closed if we had any.
Anyway, I see by the parts schematic on Stanley's website that there is a "kit, trigger valve" that looks like it has O-rings, etc. Is that the likely source of my problem? Is that something I probably can replace myself?
Any place I could likely find one of those on a Sunday?
Re: OT Stanley Roofing Nailer Leaks
Bill Earl
>I replaced the O-rings on my Bostich coil nailer a few years back. It wasn't too hard to figure out. The Borgs typically have a display with every imaginable size of O-ring - only most of the drawers are empty. My neighborhood hardware store had what I needed.
Fred Davis
>O-ring failure is about the only source of air leaks on nail guns.
Most companies like
Senco stock the replacement kit , I bet Stanley also , like plumbing leaks and septic tank overflows , only on weekends and holidays at night, in the Winter.
FredD
Service center 1.5 miles away.....
>Only open "normal" business hours.
Re: Service center 1.5 miles away.....
>Took less than an hour to get the repair. Cost $62, which probably is a little under half what I paid for the nailer 30 or so years ago, but way below what today's replacement would be.
Not too bad for a nailer that probably has thumped out 30,000 nails so far.
