We value your privacy.
>I need a long miter gauge bar for the cross cut panel jig I built. 40 inches would be nice. I could get the bar from a metals supplier, but I cannot find the little plugs which can be tapped into the sides for a tight fit.
So far, I've tried to use two shorter ones. It works, but the transition is not perfect.
over the years I have tighten old or new Mitre gauge bars simply by using a small center punch to put matching sets of dimples on both edges of the bar.
About two on each edge toward the front of the bar and two toward the back will do the trick.
If you displace a little too much metal and the bar is to tight , use a small flat Bastard file and adjust the dimples on one edge of the bar.
>Fred's right. You can use a punch and it will create a little bulge on the side of the bar. Then file it to fit if necessary. You can peen the bar itself and create a little bulge and file that if necessary.
I wonder how much you really need to do anything. Just how "sloppy" is the fit? Think about how little it would change anything if the bar moved 1/100". I have a sled I made with a hardwood runner on it and when the weather is really dry the runner is a little loose, but it does not seem to affect the accuracy enough to tell.
Another approach if you want to tighten up your bar would be to drill a hole in the side of the bar and tap the hole. Install a set screw and let it protrude enough to tighten the bar in the slot. You could put some Loctite on the screw to hold it steady after you got it right. You could put a screw in each side and in each end. Or, you could put two screws in each hole, one on top of the other. Snug the outer one against the inner one to lock them in place. Might be a little fiddly, but once you got it, it should stay put.
>I've used the T-slot miter tracks as guides. I usually buy mine form Hartville Hardware, since they're pretty much 'local' to me. They come in lengths up to 72", but I usually buy the 36" or 48" ones.
