OT - Why not stable click flooring
Bill H
>We are getting ready to install click engineered flooring (hardwood over MDF) and I'm wondering why it can't be stapled down. The instructions say it needs to be able to expand freely, but solid wood and engineered T&G flooring is stapled and surely expands and contracts more than this stuff. Can anybody tell me what the difference is? I ask b/c I laid out a few square feet of it and it seems to squeak a lot. Is this normal? Will it go away? Did I just buy crap? It is schon quick click flooring from lumber liquidators. Any advice would be greatly appreciated.
Thanks in advance,
Bill
Re: OT - Why not stable click flooring
Bill Howatt
>No idea about the stapling other than the clic connector milling and the thickness may not support fastners properly.
I installed Columbia engineered hardwood and it is fine. If things make noises it usually is because something is moving too much. Is your subfloor flat? The spec for floating floors is tight.
I spent many, many more hours flattening the floor (it was bad) than putting down the floor.
Bill
Jesper, Denmark
Jesper, Denmark
>Usually there is a thin foam type underlayment that prevents the squeaking. Did you use that???
No manufactured flooring in this house. Most of the floor boards are original 1928 slow growth pine from somewhere in the Baltic region, probably Poland. They do make some noise and the gaps between the boards couold be termed an issue, but it matches the house. No oil or varnish, but a strong soap solution once or twice a year takes care of the dirt.
Bill H
>Bill,
No the floor does need to be flattened. I sanded the high spots as much as I could, but I need to fill the low spots. Did you flatten w/ leveling compound or shim w/ felt and/or shingles? The leveling compound seems like it would be hard to get right.
Thanks in advance,
Bill
Bill Howatt
>I used lots of things except shingles (because I didn't have any) - old vinyl flooring, tarpaper, various plywood. I had a 2 perpendicular crowns caused mostly a couple of support beams that had sagged.
I also used some floor leveller but it is quite expensive if you need a lot and rather messy. If you use cement based leveller whatever you do, avoid getting it too high anywhere since if is a difficult dusty mess to sand down. I would build up the low spots with other material and then feather the bumps out with leveller.
The flooring store told me that they often use old vinyl flooring for filling.
billh
