Band Saw Blades
Band Saw Blades
Band Saw Blades
YonakBa
>I seem to go through quite a few band saw blades. I bought a bunch of Bahco blades, figuring it was a step up from the bargain (read "cheap") blades I had been buying which were breaking long before they got dull. Well, the Bahco blades are good about not breaking, but they get dull very quickly.
I'm not real interested in a blade that will leave a really smooth finish, but I would like one that's thick enough and hard enough so that both the breakage and the dulling even out to happen about the same time, and, hopefully after many hours of use. Anyone got any suggestions as to where to find blades that last ?
Re: Band Saw Blades
Re: Band Saw Blades
William H. Falberg
>Bahco carbide tipped?
Re: Band Saw Blades
Blade breakage
Bill Tindall, E.TN
>Blades break because they flex and fatigue. "Thick" is not what you want to avoid blade breakage because a blade too thick for the wheel diameter will fatigue and break prematurely. Almost anywhere will have a business that sells Lenox and/ or Starrett blades. These blades perform satisfactorily for furniture factories that run these blades all day.
In addition to wheel diameter, various factors in the set up of the saw can lead to premature blade breakage. In any case don't let the saw run when you are not cutting something because is still flexing and fatiguing.
If blade wear is an issue then you could consider a carbide blade.
Re: Band Saw Blades
Re: Band Saw Blades
Curly Smith
>You don't say what you're cutting that's so problematic but are you sure it's the brand of blade that's the problem?
Are you using blades with the correct TPI for the task? Too low TPI and you risk kinking the blade, which will ultimately cause it to fail. Too high TPI and the blade will have a tendency to run hot unless you significantly slow your feed rate.
Are you forcing the cut and not giving the blade sufficient time to clear the saw dust? If so, the blade will get hot and a hot blade rapidly becomes a dull blade, which leads to more forcing of the cut, which leads to blade flexing and breakage.
Is the blade properly tensioned? If you're using carbide or bimetal blades are you certain that your bandsaw can properly tension them? A lot of the 14" bandsaws can't tension a carbide blade and are iffy on the bi-metal blades.
Additionally, you need to select the correct blade width to match the task, narrower blades to make curves, wider blades for resawing or straight cuts. If the blade is too wide then it will bind, flex and fail if you persist in using it.
Finally, are you cutting bark? If so, you should take the time to strip the bark, at least in the area of the cut, as it contains dirt which will quickly dull your blade.
I use Olson blades or other similar cheap brands for the "not real interested in a blade that will leave a really smooth finish" that you describe. I sharpen them when they get dull and they last a long time.
Re: Band Saw Blades
Re: Band Saw Blades
Jack Prescott
>You cannot buy better band saw blades than those made by Suffolk Machine. Go to "suffolkmachine.com" to review their story. You will not be sorry!
Re: Band Saw Blades
Re: Band Saw Blades
Yonak
>This issue is with my Delta 14" band saw. I am cutting 3/4" soft maple, the tightest curves being about 1/2" ~ 7/16" radius. The blades I use for this are 1/4", 6 TPI, .025" thickness. I admit I do cut pretty fast, but I don't notice sawdust clogging the teeth, and, with the fairly coarse tooth placement and medium fast cutting speed, it doesn't produce fine dust.
Blade tensioning is done by the operator on this saw and it's possible I do tension the blade too tightly, as I have been tending to be experimenting, trying to find the right tension. (As an aside, how do you know when you've got the right tension ?)
I have not been using carbide blades because I'm basically cheap, but I'm thinking it will be a good idea to try that to see if it's effective and economical in the long run.
Re: Band Saw Blades
Re: Band Saw Blades
William H. Falberg
>Do you ever wonder how I cut 1/2" radii plugs out of 16" deep Doug Fir with a 1/2" blade? There's a clue there guys. Can you see where it leads? Yonak: you're getting some really bad advice here. Rounding the backs is good; disregard the rest. Think instead: "set angle". You're on the right track with experimenting on different blades.
Re: Band Saw Blades
Re: Band Saw Blades *LINK*
Thomas S Stockton------WebKitFormBoundaryRU4sWQOIA
>I have really good luck with lennox brand bi-metal blades. I would check out the link below and call them they are very knowledgeable about bandsaw blades and ask what they think.
Tom
http://www.hastingssaws.com/
Re: Band Saw Blades
Re: Band Saw Blades
Curly Smith
>Below are a few websites that give troubleshooting and blade selection advice. From them, you'll find that:
- premature blade breakage results from the wrong blade selection, too much tension, cutting too fast
- premature dulling results from improper blade break-in procedure, feed rate too high, blade getting hot
Lennox Band Saw Blade Trouble Shooting Chart
General "How-To's" for all Band Saw Blades
Band Saw Blade Break-In Procedures If you're not doing this then you should. A new blade will cut so fast that the kerf can't clear, the blade will get too hot and an instantly dull blade can result.
Two things come to mind, first a 1/4" blade is too wide for a 7/16" radius turn (the recommended minimum radius for a 1/4" blade is 5/8"). Granted, you can nibble around the curve and create a wide enough kerf but you'd be better off using a 3/16" blade. Second, you'd probably have better luck with an 8 TPI blade.
As mentioned, it's also helpful to round-over the back of the blade if you're going to be making tight curves.
Lastly, when using small blades it's helpful to make wooden guide blocks that completely enclose the blade. You'll get maximum blade support and the wooded blocks won't damage your blade. Sadly, I don't recall which band saw book provided this recommendation so I can't give proper attribution. But I can confirm that it works...
Re: Band Saw Blades
Re: Band Saw Blades
Yonak
>Thanks for the good tips and sites, Curly.
