We value your privacy.
>How practical is it to drill end grain to a significant depth...say 14-18 inches?
I want to try my hand at building a flute. I know I can route a 3/4" to 1" diameter groove in two matching halves of wood and glue it together, but, for some of the woods I would like to try, I would prefer to have no visible line.
If drilling to this depth is practical using either an extra long bit or bit and extension, what kind of bit would be best? By hand (brace/bit) or using a drill or drill press? Woods would range from cedar to birdseye maple...very soft to quite hard.
>Joe do a search for flute making or drilling flutes. I found some great information on long hole drilling a year or so ago when I was looking. They generally use a D drill or start with a lamp auger.
>It is relatively easy to drill end grain. The difficulty is having your entry and exit holes line up :).
Do you have a lathe? If you have a lathe, it is easy. Just go ahead and drill and then true the exterior to the entry and exit holes. If you don't have a lathe, you can try a lamp auger bit. I've also had reasonable luck drilling long, end grain holes with "ship auger" or "aircraft" bits as opposed to the long spade bits. IMO, the long spade bits "wander" a bit too much.
>I have had mixed results, it depends on the stock. It would make sense to me that riven stock would be a better choice for deep end grain dilling because the bit center does not cross multiple grain changes.
Does this make sense to anyone else or do I need to dry the wet behind my ears?
>Use caution when selecting the wood. I think it was Fine Woodworking that had an article about a man who made a recorder. Played it for several hours and woke the next morning to find his mouth blistered.
As for the hole, I have had success by drilling with a standard bit to its max. depth, then use a heated rod to burn the rest of the hole.
You would need to pratice this and not get over agressive, but it does work, start small and go bigger. It would be best if you made the hole prior to cutting the wood to size, you can use the hole as a center point for the lathe and keep hole true to the flute. This, at one time, was a common practice.
