We value your privacy.
>Hi, I'm in the process of installing my first full mortise lock into a small keepsake box I'm making. I've gotten past the hardest parts, which is cutting the various sized mortises for the lock mechanism, but I'm curious if there is a trick to nailing in those tiny nails for the key hole cover. What technique is there to holding them in place and nailing them down that doesn't involve cursing?
>stick it on with CA glue and drill pilot holes for the nails just a few thousandths less than nail diameter. You do have a set of number drills? Everyone should, for this kind of application and others.
>Sometimes, small nails can be "driven" with less grief with a pair of pliers, if you can reach the back side of the wood involved with the other jaw of the pliers.
In addition to a set of number drills - and I agree with Bill Tindall, they're useful frequently - every woodworker should have a good set of channelock type pliers for this purpose. There are marginal ones, good ones, and great ones; insist on the great ones. I have a pair of Knipex pliers (from my brother) that I love (I've actually used them as a pipe wrench!), and Channelock brand are also good.
Great for picture framing, for instance.
Pad the jaws - cardboard, small chunk of wood, old credit card - for anything that you don't want to damage.
>I use doublestick tape for sticking down the escutcheon. A needle nose pliers is good for holding those eensy nails while you nail them with a light (4 to 6 ounce) hammer. Or, use a small piece of heavy paper; stick the nail through the paper, position the nail over the hole, and tap. When the nail is almost in, tear off the paper. Definitely predrill as others have mentioned.
>Bill, I do not yet have a set of number bits. I was checking them out on Lee Valley's site. The have two different size ranges (I ordered the smaller set to start with. Can you please explain the concept behind the numbers for these drill bits? What do the number represent?
I just did a search of the Knipex channel locks. A bit more money than the type you would find at the Borg - but I have to admit, they look extremely well made. I'll have to add them to my wish list for the future.
>Fred - Excellent suggestion. I had never seen this tool before, but looks to be perfect for my needs and is not an expensive tool. I ordered one from LV along with them numbered drill bits that Bill suggested.
Thanks
Bart
P.S. Hope to see ya next year at Grumbine's assuming he holds his annual picnic again.
>I know you addressed this to Bill Tindall, but I'm Bill, too, and I'm here first...
Number drills start around 7/32". Lower numbers indicate larger drills - that is, a #1 is largest, a #80 smallest. Unless you work a lot in miniatures, you're unlikely ever to need the #61-#80 set, and those bits are so small you need a pin vise or something similar to drill with. Any drill bit #50 and smaller (remember: number going up) more or less requires that you hold your breath and think pure thoughts the whole time you're using it, and, even then, breakage is common.
Your hardware store may have number drills individually, useful for the inevitable breakage of the smaller bits.
You may be saying, "why are the numbers upside down, higher number meaning smaller drill bit?" The short answer is, "because." The longer answer is that number bits were originally machinist's bits (still are, predominantly), and this inverse number/size relationship is not uncommon in the metal trades for some reason. You find it in sheet metal and wire sizes too.
For woodworking purposes you may get by with a cheap foreign made set so long as you are just drilling wood. You can get a set of 1/16 to 1/2, plus the number drills, plus the letter drills, all in a spiffy case for $40 at places that sell import stuff. You can mail order such sets from Travers, MSC, ENCO and probably Ebay has a dozen places. Order a pin vise while you are at it.
I use my number drills on every project that involves nails or screws. A micrometer is also handy so you can measure a brad and know what size drill to select. Just a few thousandths less than the brad diameter is suitable for hard woods. You will never again split the wood or bend the brad or have it run off course. I usually use an old fashioned "egg beater" had drill for drilling pilot holes (more control) or just my hands with the pin vice.
