We value your privacy.
>Just saw the LV news letter with the quartz radiant heater. Anyone on the fence about it might want to snag one (or more ?) before Mr. Lee runs out again. Been loving mine for a couple winters now. Plenty-o-heat where you need it ! AND a pretty good bargan.
>Weren't they offering one a couple of years ago with a 100W lamp and made in USA? I didn't jump on that one quickly enough, and I seem to remember the manufacturer called it quits. This one doesn't say, so I'm assuming China. Which one do you have?
>I bought two when they originally came out and didn't like them. I switched to a 220V construction cube heater to heat my shop. I didn't like them because they didn't heat the shop, they heated whatever was facing them so your front face stayed warm and your back face stayed cold. I gave one away to a friend and the other got moved a couple of times and now one of the heating elements is broken. It is the only thing that I ever bought from LV that I was less than happy with and probably shouldn't have bought them in the first place because their shortcomings were clearly stated in the original catalogue copy.
>but I don't see a Made in China label. Seems to be a Marvin 7260, out of Urbana, OH. Has two tubes, multiple heat settings, a halogen light. This thing.
It's definitely like Gerry says - "they didn't heat the shop, they heated whatever was facing them so your front face stayed warm and your back face stayed cold".
>I remember now, because we have a local Borg-wannabee called Marvin's, and I thought it odd (and probably confusing to some folks) that they sold this same heater. Missed my chance there, too.
>Got mine on closeout at HD. Paid $25.00, but mine has no light. I turn it on bout 20 minutes before I go into the gara...er...shop to work, and have it pointed at the concrete floor. After the 20 miutes, the floor ahsbeen heated and radiates the heat into the surrounding area, which is just about enough for me. I like mine, except that I have to replace the string for the switch. I yanked too hard!
>I like my heater just fine. I also fire it up 15-20 minutes before I go out. It heats up my workbench and other stuff and tends to radiate the heat from those various items. I bought it knowing it wouldn't heat the whole shop/garage but after an hour or more of use I find it does actually warm the area a bit. Not toasty, warm snug but enough to take off the chill and make it pleaseant enough to work. Not like winters along the Central Calif coast are all that harsh. Works fine foe me.
Too bad they went out of business. Hope I can still find a replacement bulb, better look now and stock up on a couple.
Oh, and mine also had the pull string problem. Replaced it with a light pull chain and it works fine.
>Check out your farm supply store. Many of these heaters use the same type of infrared heat lamp that are used for poultry and infant animal heat lamps. They should cost you about $4.00 apiece. The clear ones work just as well as the red ones. They put out the same heat.
