Pressure washer recommendation
Bill Tindall, E.TN
>I need a pressure washer for occasional use to wash the mold off house trim and porch floors and to wash poop from sheep pens, etc. I tend to prefer heavy duty consumer or light commercial stuff but I have no idea how much pressure & flow I might need for these tasks. (I don't need/want to strip paint or mortar from the bricks.) I want one good enough that I won't need to buy another any time soon but cost is not unimportant.
Re: Pressure washer recommendation
>Home Depot
brand is "Excel", size is 2800psi. Look for and confirm a Honda engine and a Cat pump. Take no substitutes. I bought a rebuilt and the thing has been bullet proof.
Ken Oakley-Sunny St. Cloud, Fla.
>Mine is the 2300PSI version of the one Mark suggested- Everything you will ever need or want. If it is a Honda you can't go wrong.
Karcher
Dustmaker Mike
>Honda Motor and Cat pump. 2400 PSI 7 years old and still going strong. I think the Honda motor is the key one maybe two pulls and it is running.
Cat pump?
Bill Tindall, E.TN
>Is Cat a brand, style...?
Briggs
Bill Tindall, E.TN
>My irrigation pump came with a Briggs engine and one screw holding the carburetor on. I saved (temporarily) $150 by not getting the Honda engine on this pump. Carburetor loosened, mixture became lean and burned the valves before I caught the problem. Briggs would not warrant their error. That was the last Briggs engine there will be on this farm.
Michael J Bitetti
>I have an Excel 2800psi 5hp Honda engine and my dad's Karcher 3300psi 6hp Honda engine. They are both excellent. One suggestion though: Always have the trigger on when the engine is running (I keep a clamp on mine). Even though some say you can run it for a limited time, the rapid heat buildup is what will eventually destroy the pump.
Joseph Mulherin, Sr
>Bill, you might check out the Harbor Freight ones....they have several to look at 1600psi to 4000psi...and lower costs too
Re: Cat pump
>Cat brand P-W pumps are the best you can get in this price range for "cold" (up to 100�) water washers. Look for their signature light blue color and you'll see the cat logo.
Jason Roehl in Lafayette, IN
>Two words: belt drive.
All others will rattle the pump to pieces, some sooner than others.
Renting is not a bad option. Set aside a day each year to get all your pressure washing done and rent one. You're done in a few hours, and the maintenance and repairs fall to the rental company and you can waste your time in other ways.
Jason
