OT Wiring TV and Phones??
>What is the current material for wiring TV and Phone?
I am converting an old house into apartments and want to wire in Phone, TV, Satellite, Computers. They seem to be blurring the lines, but this house is way out in the country and the phones will probably have DSL for the Internet and then there may be satellite TV.
So, CoAx and What? Or What and What?
Thanks.
Re: OT Wiring TV and Phones??
Rod Peterson * Ormond Beach
>When I did my remodel, I put in a lot of wiring for TV and phone/network. For TV I used RG6 (pretty much standard TV coax). For the phone/network I used CAT 5 cable (4X twisted pairs). I made two runs of each to each location (generally each room—some rooms have two locations).
Unlike CAT 3, which was often run in a point to point loop, all my runs were home runs. I bought a "geek box" to use as junction box and put in a punchdown block to tie all the CAT 5 runs together. The TV cable is distributed a little differently. In my case I basically have two receivers, so only needed to use two of the several cables, both connected to the incoming satellite cable by a splitter. There are larger distribution boxes that can be used (but you'll probably need an amplifier which will require some power).
Two runs per room sounds like a lot, but when you buy the cable in a 500' roll, it's not that expensive. You'll need each of the two runs of CAT 5—one for phone and one for the network. Yes, a dedicated four pair for POTS (plain old telephone) is overkill, particularly since you could run DSL along with the voice, but if you want to run a network, you're golden with that second line. Of course nowadays, there's wireless, but that may not reach everywhere.
In the case of TV, if you had the satellite going to a room with a dual receiver, the second line can then carry the output of one of the tuners to a second television in another room.
Basically, I didn't want to ever have to go into the attic again, so I ran a lot of wire…once. Not everyone will need/want to do what I did.
Rod
Bill Howatt
>If the house is way out in the country, it may be too far from the telephone office for DSL. Suggest you check, it could mean another satellite feed for faster internet access than dial-up.
Ethernet cable performance is affected by length of runs so you can often get by on a lower standard of cable if the run is relatively short. However CAT6 is now the current high-speed standard and I would use it if the price difference isn't a show-stopper, after all you are building the cabling into the walls so you want it good into the future as well as now.
Like Rod said, the current TV cable standard for statellite is RG-6 which is a bit larger than the old RG-59. RG-59 does work but best to use RG-6.
Re: Let me offer another thought
Glenn Madsen near San Francisco
>You can wire everything up for today's standard pretty easily. The fact, though, is that those standards have been changing, and quickly. Sometimes, the wiring doesn't last much longer than a good paint job on a room.
Consider the notion of running the inexpensive wiring conduit in the walls, so that pulling new cables becomes pretty easy. I'm talking about the plastic, spiral wound looking stuff that's moulded, and comes in large rolls. Easy to install, it means you can change and repair over time without drywall work.
Believe me, there will be changes. I've redone mine three times in eleven years. I wish I'd done the conduit.
Good idea to consider!
Bill Howatt
Thanks, and one more question?
>OK, Cat 5 or 6 and Coax, Maybe in conduit.
Is it OK to run them in the same conduit? I think I know you are not supposed to run them closely parallel to 120/240 volt stuff, but how about each other?
Jason Roehl in Lafayette, IN
Re: Thanks, and one more question?
>Not a problem. RG6 is well-shielded, so there should be virtually no crosstalk with the Cat5/5e/6 cable. Even better if you get shielded twisted-pair cable.
Just a note, when you do RG6, you'll need a somewhat spendy connector tool. With RG6 you don't just crimp on an F-connection like the old RG59 had. The RG6 connectors use a friction fit, so the tool pushes a nylon bushing into a metal sleeve to grab the cable.
I've never run twisted-pair cable, I've only ever used pre-packaged stuff, so you'll probably need a special crimp tool for that (and some understanding of the pinout protocols for the 8 wires).
Jason
If you use Leviton style (there are other manufacturers and available at the boxes) plates and connectors you'll need a 110 punchdown tool. The packages of connectors come with a plastic one, but they're only good for a couple of connectors and then you'll be wanting a better one. Mine is perfect—has both 110 and 66 heads.
Color code is easy. Each pair has a primary (solid) color and a complementary (striped) color. The proper order for each pair (there are actually two choices—some research will reveal what I'm talking about since I can't remember it well enough to articulate) will probably be blue, orange, green, brown. Each connector is marked to show which ones go where.
Rod
Re: Note: Crimp tool is not Punch tool
>These are two different things.
The punch tool is classic for the telco technician, who attaches twisted pair wiring to clip type connectors. The 110 and 66 blocks mentioned. Secures and trims in one punch motion.
The crimp tool is for the RJ45 connectors the ethernet connections use to plug into the electronics.
A bad punch tool is hard to use. A good one might run $50.
A crimp tool should not be needed, though. Run to the Leviton plugs in the room, commercially available Ethernet should go from there to the systems. Way too cheap to buy vs. make.
Rob Hix in King George, VA
>When deciding on the wiring standard to use for the ethernet cable, keep this in mind. One of the two standards (I do not remember which) will allow you to plug a regular phone cable into an ethernet jack. This would allow you to put RJ-45 jacks in all of your plates and use them for phone or for network whichever you desire. I will look today and see if I can come up with the answer to which one to use.
Rob Hix
Wiring Info *LINK*
Dustmaker Mike
>Here is the color coding for RJ 45 RJ 11 the T568A & B standard wiring
Color Code
Other things to consider
Joel M Kramer
>The idea of running the cable inside conduit is a good idea. The added thought is to run a drag line within the conduit so that you can pull additional wire through it in the future. I would not recommend using the installed wire to pull replacement wire though with. The second thought is that to keep the bends to a minimum, (max 3 or 4 90 degree bends) and do not fill the conduit more than approx. 50%. Anything above 75% fill depending on length of run & number of bends becomes impossible to pull through (even if you use wire soap/lubricant). Also remember that there is a maximum pull force that can not be exceeded, else you compromise the wire integrity. The other thing to keep in mind is that as you move from CAT 3 through to 6 the requirements for building the connections (attaching the wire to connectors & blocks) get a great deal tighter. These requirements have to be adhered to or else you will get crosstalk at these points.
