Kinda OT (but not really) Cutting Acrylic
Tom Rex in TX
>I need to cut a 24� x 24� sheet of acrylic that is 1/32� thick into strips 3� long x 2� wide.
How would you do it?
TIA
T Rex
Tom Rex in TX
TIA
T Rex
Re: Kinda OT (but not really) Cutting Acrylic
Bill Earl
>For something that thin, I'd score and snap. There are utility knife blades made for scoring, or you can use a carbide laminate scoring tool.
Jesper, Denmark
>A negative rake blade on the table saw will work wonders. A standard crosscut or combo blade will also work with a careful feed rate.
A little water cooling from a spray bottle helps a lot. It does not need to be soaked, just misted.
Zero clearance is essential for thin plastic
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>If you have a TS sled, you can carpet tape a scrap over the slot, so when you cut through, there will be no space for chatter. Use your finest low hook blade with a moderate speed. Too slow will melt the edges, dirty dull blades make it worse.
Re: I agree, use a knife
Brian in Brighton
Agree! tape the bottom of each - tho
G Deavers
>This stuff is brittle! SHARP low rake blade as well.
Wear safety glasses
Yonak
